SOURCE: restriction code to unlock nokia 6300
No Brother it is paid service and many providers give it. U may search them here at fixya or other mobile support forum like GSMHOSTING, GSMHELP etc. No one can give u such code because it is part of Nokia security. The code is as per cell's unique IMEI and only can be obtained by professional software tools like BB5 box and other compitable tools. It is advisable to visit nearby mobile technician who have such box. He will charge u for that. If it sounds informative do not forget to vote.
SOURCE: nokia 6300,vodafone help with restriction code please
For IMEI: 358647018639597
Network: 50503
#pw+449947467741741+1#
#pw+127304540575606+2#
#pw+483907607161006+3#
#pw+147864365560166+4#
#pw+026103247463600+5#
#pw+443947466101547+6#
#pw+325126041333022+7#
To enter the code to the phone (switch on without SIM card).
Input the Code in the phone as follows:
#pw+??????????????+1#
#pw+??????????????+2#
#pw+??????????????+3#
#pw+??????????????+4#
#pw+??????????????+5#
#pw+??????????????+6#
#pw+??????????????+7#
Here: ?????????????? You should enter generated code.
First code in the end of the string must be added + 1#
Code number 7 in the end of the string must be added + 7#
If you have proper software and You know on which lock, phone
is closed just simply enter proper CODE.
If YOU DONT KNOW - which lock is closed do the following:
1. Enter the first code, if it’s the wrong code - WAIT 30 seconds!!! And then:
2. Enter the code number seven this will open all locks.
How to get 'p' 'w' '+' signs?
Press * several times on keyboard of phone...
!!Warning!!
If the codes don’t work after entering 5 codes You will lock the ‘CODE UNLOCK FUNCTION’ and it will be possible to unlock the phone only by using a cable/device.
All the best
There are many websites and applications which claim to generate unlocking codes for nokia phones for free, I don’t know if they work but you can certainly try them at your own risk:
Hope this would work for you
Thanks for using Fixya
SOURCE: Unlock Restriction Code Nokia 6300 with Vodafone Australia
hi i have a nokia 6300 locked to the vodafone network in australia the imei # is 353508026370192 if anyone could help with the restriciton code it would be much appreciated thank you. e mail is abaileyboi@hotmail.com
SOURCE: Nokia 6300 Australia Vodafone requesting restriction code
Handset Unlock - Instructions
Please find below the instructions to unlock your handset.
Handset Unlock Procedure for IMEI:
353508029865248
Your unlock code is:
426850229882845
Manufacturer/Model:
Nokia_6300
Nokia 6300
PHONE UNLOCK PROCEDURE
PLEASE READ THE INSTRUCTIONS CAREFULLY BEFORE YOU ATTEMPT ANY
UNLOCK PROCESS
This procedure unlocks the handset from being network restricted from only
using SIM cards from Vodafone Australia. In
case of difficulties, please refer to the FAQ listed below
1.
Take note of the unlocking code shown above
2.
Insert a Non-Vodafone Australia working
SIM card.
3.
Ensure the phone is charged and then switch the phone
on.
4.
Optional
Step: If the SIM card has a PIN, enter your PIN number. (See FAQ below)
5.
The phone will then display a message. The most common
is “Phone
Restricted”. Select
“undo” by pressing the middle
soft-key button. (Different message? See FAQ below)
6.
Carefully read step 6 before
attempting to enter the unlock code. This step has the potential to PERMANENTLY
BLOCK YOUR PHONE!
Enter into the phone #pw+ followed
by the 15-digit unlocking code then +1#
(Unlocking code is shown above). Do not
enter the 15-digit IMEI number by
mistake
To enter +
press the * (star) key two times
To enter p
press the * (star) key three times
To enter w
press the * (star) key four times
For Example: If your 15-digit unlocking code is 123456789012345, enter the following in
sequence: #pw+12456789012345+1#
(When entering the unlocking sequence it
disappears? See the FAQ below)
7.
Then press “OK”
8.
The handset will display “Phone
restriction off”
unlocked after successful entry of the unlocking code. This will be confirmed if
you can make and receive calls with the Non-Vodafone Australia
SIM card. (You will need reception and phone
credit with the different network provider)
