Dell TrueMobile 2300 Wireless Router (tm23003) Logo
Posted on Jan 30, 2011
I cannot remeber my security key. How do I find my security key
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 15 Answers
  • Posted on Jan 30, 2011
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
15
Questions
Helped
2341
Points
36
Have you ever SET a security key?
because if not it will probably have a factory default set, which it SHOULD tell you in your User Manual.
I'm not familiar with the Truemobile 2300 Router, but most routers either have a reset button of the back or bottom of the case, or their may be a hole marled "reset" that you can poke a cocktail stick or simular (non-conductive) object into the hole to reset it, this MAY set it back to Factory default and wipe any security key, There again it may not.
If no good, Have a look at:-
http://search.euro.dell.com/results.aspx?s=gen&c=uk&l=en&cs=&k=Truemobile+2300&cat=all
I can't get my son's DSI to connect to the internet. I am using a vverizon 5 spot. We go to advanced setup it said setup complete then we do connection test (which is on connection 4). It says...
as i remeber, the secruity code is the one that you put before you access a locked internet connection and the passes are usally wpa styled password. you should put go to run>cmd>type ipconfig>and find you ip adress and put your ip on you internet explore. if should directly connect you to the router figuration or the log in your adminstrater and go to security tab or it might be diffrent. find your pass and put it on the dsi. hope it helped.
2helpful
2answers
Put a password on my samsung champ 3300k and cannot remeber the password. what to do :(
If you type the worng key more than 3 times it will ask you for a PUK code.
If its a PUK code, call the customer care and after asking you several security questions, they will provide you with the code.
Goodluck
May 02, 2011 • Cell Phones
3helpful
2answers
My jimmy starts and runs when it wants to then sercruity light comes on and shuts it off
Yes the truck came with a stock antitheft system. That IS what the security light is about. Check out this link. Everything you need to know is there.
http://vatspasslockpasskeysecurityhelp.yolasite.com/
How to password protect a d-link airplus wireless access point.
1) Switch On the connected router enter the IP address 192.168.0.1 in the address bar at the top of your browser.
2) Give admin as username, leave the password blank, click ok.
3) In the left panel, select Wireless to open the Wireless Settings.
4) Change SSID. Replace the SSID which you will remeber.
5) For Security, select WEP. Select Shared Key for Authentication and type in your key. eg, manage1234
6) Click Apply
1helpful
Forgot passowrd, how to get my password
Well, unless you remeber it you cannot get it. Your option is to reset the router and start over. Give new password and reset the sytem name, and remeber to secure the wireless portion.
What is wpa pass phrase while setting wireless printer
WPA with a Pre-Shared Key (PSK), also known as personal. PSK is entered as a pass phrase between 8 to 63 alphanumeric characters in the ASCII format at both ends of the wireless connection. Although PSK accepts a minimum of eight characters, for proper security, it is a good idea to use ample length and should not use a commonly known phrase. This phrase is used to generate session keys that are unique for each wireless client.
WPA pass phrase is a password for the wireless network to make it secured. You can obtain the WPA pass phrase when you access your router. Check the manual of your router for the address, username and password of your router. Go to wireless settings, you will see ther the SSID or Network Name, Network Key or the Pass Phrase and Authentication (WPA/WPA2/WEP). You can personalize the SSID,Network Key and Authentication. Remeber that for you to connect wirelessly the Authentication and Network Key on the router should match the Network Key and Authentication of the Printer or Computer.
Thanks for using Fixya,
I need master security code for nokia 2626
there is no calculator to calculate security code for your 2626. go to nokia service centre or other professional who have particular software to reset it.
9helpful
Nokia 1650 locked,dnt remeber d password!
I m from nepal. i kept my sim in t mobile side kick3 but cell asked me code
wat u need to do is etheir type in 123 or 000 then after it is active then go to menu then to key guard and security then turn on or off security so it will not come on if u pick turn on for privesy if someone wants to invade ur text or clls keep it on. first turn off security then turn it back on and it will say type in 3 digit code type 1 u will remeber then ok press diangnal arow the it will set so whenn u come back to it it will ask u for code and u tpye it then ur set
Security Code
Try contacting Tracfone customer service. Did some digging and it seems if you try and fool with these too much it might lock the SIM down permanently. See: http://www.howardforums.com/showthread.php?threadid=96462
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
