SOURCE: KENMORE GAS STOVE OVEN LOWER BURNER WON'T WORK
First look to see if the ignitor is coming on. Most common problem is the ignitor is weak or just bad. When the power is applied to the ignitor it glows and builds up resistance to open the gas valve then it lights. If the ignitor is weak or bad it will not build up enough resistance for gas to come into the burner. One sign of this would be a "woosh" sound when it trys to light. If the ignitor is coming on but not lighting it is most likely the ignitor is bad. Should have a full glow. Also, if the ignitor looks whiteish in color this is a sign of it going bad. You can compare to the broil ignitor to be sure. If the ignitor doesn't come on at all will need to see if you have power to the ignitor. Let me know what you find and let's solve it before you rate the solution.
SOURCE: oven control panel out
not likely a bloiwn fuse, you would have to gain acees to the control panel itself and check for incoming power supply, if your geting power to the clock the n youll need to replace clock. in the cabinet somewhere will be a wire diagram/trouble shooter. to aid you along
SOURCE: Tappan gas stove,oven not lighting
i am unable to use my oven on my tappan gas range. every other part of the range works wonderfully. the oven just will not light
SOURCE: gas stove oven ignitor comes on intermttently on it's own,without starting burner
hi thanks for the question did you replace the ig niter if you did not . replace it the igniter does not get hot enough to ignite the gas replace it thanks the appliance doc
Most likely a hot-surface ignitor has failed. If it doesn't consume enough current, the gas valve won't open. It's usually a fairly easy fix, once you gain access to the ignitor and have a new one to replace it with. Make sure you unplug the range...
