To change from fraction to decimal, all it takes is a keypress. (change key)
.Not all decimal results (approximations) will be converted to fractions.
Anyway, if you want to set the calculator to display decimal results only,
Press SETUP
Press 2:EDITOR
Select 1:LINE.
Visit www.mathsatsharp.co.za to download a user friendly guide on using the EL-535HT and to download a free calculator for the computer based on the EL-535HT
SOURCE: Sharp EL- M332 caluclator- have
Hold (C.CE) then whilst holding it press (M+) for approximately a second and it will move one place along in the three settings (F, 2 and 0) F shows full decimals, 2 shows 2 decimal places and 0 as yours is set to now round to the nearest whole number. I have just been sat at my desk trying to work this out as my calculator was too set to '0'. Took me reading the 'DEC DET' text with lines pointing at 'M+' and 'C.CE' to finally crack it!
Hope this helps.
SOURCE: how do i get rid of the "P" on my sharp caculator....
On the back of the calculator, there is a little "reset" hole. Use a pen and press it into that hole for a few seconds, then release. You should now be able to turn on your calculator as if it was brand new from factory without the "p".
SOURCE: EL-W535 how to use
Download the Operation Manual for SHARP EL-W535 from SHARPUSA:
http://www.sharpusa.com/products/TypeManuals/0,1083,15,00.html
You will find the download link near the end of the page
SOURCE: I have just purchased the
Thank you for purchasing the SHARP Scientific Calculator Model EL-W531/W531G/W531H/W531HA/W535.
About the calculation examples (including some formulas and tables), refer to the reverse side of this English manual.
Refer to the number on the right of each title in the manual for use.
After reading this manual, store it in a convenient location for future reference.
Notes:
• Some of the models described in this manual may not be available in some countries.
• This product uses a period as a decimal point.Displaying calculation results
When possible, calculation results will be displayed using
fractions, r, and ?. When you press U, the display will cycle
through the following display styles:
• Mixed fractions (with or without ?) ? improper fractions (with
or without ?) ? decimal numbers
• Proper fractions (with or without ?) ? decimal numbers
• Irrational numbers (square roots, fractions made using square
roots) ? decimal numbers
Notes:
• In the following cases, calculation results may be displayed
using r:
• Arithmetic operations and memory calculations
• Trigonometric calculations
• In trigonometric calculations, when
entering values such as those in
the table to the right, results may be
shown using r.
• Calculation results may extend off
the edges of the screen. You can
see those parts by pressing l
or r (depending on whether the left or right portion is
hidden).
