Well, I would guess that if you are hooked up now, then you have a wireless router. If this is the case then you should have rj-45 (ethernet) ports on the back of it also for lan hook-up also. Must come with atleast 4 LAN ports, 1 WLAN port (for the incoming internet signal from your cable/dsl modem), so if you use a reg. ethernnet cord, then yes you should be fine hooking your ps3 to your network(via ethernet cable to your wireless router from the ps3).
Hope this helps...
