You may have a couple problems here or just one.
1. Check the incoming gas pressure I believe on this oven it requires 7" of water column to operate.
2. check the output gas pressure at the gas valve it should be around 3.5" water column.
Looks like to me that either your utility company might have restricted the supply pressure or you may have a faulty gas valve or the gas valve might just need adjusted.
Hope this helps you
please rate me
