Reprogram the remote: turn ignition on, press and release valet switch one time. Press and hold valet switch. While holding valet switch, press lock button on remote. The alarm should chirp to confirm entry into the programming mode (when you press and hold the valet button) and when you press the lock button. Turn ignition off. Test remote.
i tried that and is still doesnt work
Make sure that the unit is not in valet (LED on solid) before attempting to program system. If the batteries in the remote are good, check the fuses at the alarm. If the fuses are good at the alarm, you may need to disconnect the control module to reset the system.
took it in and they think its the brain
