Motorola Mobility H390 Bluetooth Headset Logo
Anonymous Posted on Jan 24, 2011
I need a driver to work on my cpu - Motorola Mobility H390 Bluetooth Headset
Muntejaya Ginting
Level 3:
  • Master 10,422 Answers
  • Posted on Jan 24, 2011
Muntejaya Ginting
Master
Level 3:
Answers
10422
Questions
Helped
2520764
Points
19566
  • Anonymous Jan 24, 2011
    those pages wont open
Pentium r dual core cpu e5300 audio drivers
Audio drivers are for the motherboard/computer, not for the cpu. Go to computer maker's website (or motherboard maker), locate the support page for your exact model and download the drivers there. Also, Windows update may be able to supply generic drivers that will work. Go to Start / Control Panel / Device manager and locate your Sound drivers and click on Update Driver.
2answers
Free download drivers for pentium(R) Dual-Core CPU E5400 @2.70GHz 2.70GHz
CPU does not need drivers it needs a motherboard with a bios. A motherboard has devices integrated on it the require drivers. The bios number is what you search on for the drivers required for the motherboard.
Intel r 4 r cpu 945, 3.40 ghz driver needed!
There is no driver for just the CPU. The Intel INF gives the driver it's instructions.
The only thing you need is to go to who made the motherboard, or to the MFG if it's a pre-built system like a dell, and download the chipset driver.
It will say chipset driver, or INF driver, but this is not a driver but it's what you need for the bus's and for the CPU to communicate.
Intel Celeron Cpu 430 1.80ghz Driver Download
hello, there is no driver downloads for intel celerons...if your computer will not work with this cpu, you would have to do some searching on your computer manufacture to see what cpu is supported.
thank you
When i start my cpu, cpu is working but not showing anything in the computer.
Unless there is any display to indicate the doubts are on the sections of the processor and the display drivers.
You need to check on the main board in the section of the display drivers and interface.
I just bought altec lansing bx1220 speakers but cant find device drivers to get them to work
shouldnt need drivers if sound was alredy working on cpu,,download audio driver for your computer at website of manufacturer of cpu,,
3answers
7helpful
2answers
Driver for prescott 533
I think you're a little confused LUNISOZZI. Allow me to explain.
The term Prescott is a type of CPU. 533 is the (FSB), bus speed that the CPU can run at. There is no driver needed for the Intel Pent 4 Prescott 533 CPU. When updating windows there may be a revision update for the Pent 4 Prescott 533 CPU listed in windows update to the left under hardware. If you're CPU is not beeing seen by windows correctly than check windows update. If you're CPU is not working in on the Asus board, than remove the CPU & check the connecting pins on the CPU. One or more may be bent or broken. CPU may not be completely seated. Thermal grease was not added or too little added between the CPU & heat sink assembly.
Why don't you explain what it is that the CPU is or is not doing?
What is the motherboard not seeing? or windows ia not doing?
I can find a solution if you can explain.
Mike
Does the motherboard for the model w3107 e machine with the sempron cpu processor driver upgrade deemed compatiable
The AMD Sempron 3100+ Processor is the highestspeed CPU you can run in the W3107 E-machine. No there are no drivers that need to enabled.The system bios sets up the cpu. Did you install this CPU?
Your E-machine:
http://www.emachines.com/support/product_support.html?cat=Desktops&subcat=W-Series&model=W3107
Top Motorola Mobility Radio Communications Experts
Dennis
ADMIN Andrew
ADMIN Andrew
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
