SOURCE: Windows Vista Many Taskeng.exe processes
Please get you system scanned by latest antivirus software since it seems a virus attack.
This behavior is strange and suspicious as well.
Thanks.
SOURCE: my 8gb flash drive is
you can try steps in below link.it may help you..please get back to us if it doesn't work
http://soluzia.net/How-to-disable-write-protection-of-USB-flash-drive.php
SOURCE: If i were delete the“Imation Flash Logout.exe”
Espanol? Vuelve y postea el problema y trata de conseguirme y me solictas la ayuda puede ser por solo $3.
SOURCE: I completely erased the files
If you have damaged or deleted the hidden restore partition on your hard drive as well as the primary partition then you will need the toshibe restore CD for that model
Toshiba sell those quite cheaply.
Other wise you would need to buy a new OS cd
Did you use the F10 option during the boot up to access system restore ?
Or did you select an option from safe mode ?
SOURCE: i can't save files to
what flash drive do you have? maybe there is switch for lock or unlock.. or try to check properties, see in the security tab. hope this useful, regard riyan.
