SOURCE: How do I open a Braun 8585 shaver to replace the
You will find batteries at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-battery-aa-nimh-p-108.html
To open the shaver body, you will first need to gently pry off the 'cap' on the bottom that surrounds the hole where the cord plugs in. Once removed the side grips will pull off revealing 4 screws. Remove screws to take off back cover and access insides. Inner parts simply lift out. Reassemble in reverse order
SOURCE: how to replace battery on braun 7526 electric shaver
1) Use a small flat screw driver pry off the bottom (where the cord plugs in)
2) Remove the silver sides
3) Using a small torq driver remove the 4 scews
4) Open shaver
5) Remove circuit board with batteries
6) Install new circuit board and reassemble
SOURCE: Braun battery replacement
Unfortunately this is almost impossible. The batteries are part of the circuit board, and Braun only authorize their service agents to replace the whole unit, and my local agent found that it had been discontinued. If you still want to have a go, two screws are hidden beneath the two grey plastic caps either side of the charging socket on the underside of the shaver which can be prized off quite easily. Once you have removed the screws, the small plastic section comes off. Now you can slide the outer casing off. A thin black cover at the back can then be unclipped, revealing the circuit board and batteries. The whole unit simply lifts out and would be easy to replace if you could find one! Rplacing the batteries would be far more difficult and risky. Good luck.
SOURCE: Braun 5723 shaver - how to replace batteries?
Remove the two screw covers on the bottom of the shaver and then remove the screws underneath. Once screws are removed, the outer case will slide off from the bottom. You will then have access to the insides and the batteries.
You will find replacement batteries for this model at shaveroutlet.com. See link below
http://shaveroutlet.com/braun-battery-nimh-2-batteries-p-105.html
Testimonial: "Thanks for quick response - solved the problem."
SOURCE: braun 5614 battery replacement. where
You will find replacement batteries at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/braun-battery-nimh-2-batteries-p-105.html
Start by removing the foil and cutter. To open the shaver body, start by removing the two round screw covers on the bottom by prying them out. Then remove screws. The insides of the shaver can then be slid out through the top. Batteries simply unsnap from their connectors. Install new batteries and reassemble in reverse order
