SOURCE: HAVING A PROBLEM WITH MY HILTI TE5 HAMMER
the bearing in the chuck is probly missing. replace the ball baering.
SOURCE: hilti dd 130 chuck
Hi Rob. If you send me an email I can send you the full parts diagram (exploded view) pdf.
paul@wysehire.gi
www.wysehire.gi
SOURCE: Cordless Hammer Drill Sfh 151 A 2.0Ah: Hi, How do you change the chuck on the Hilti SF 15...
Hi. open the chuck to the max. inside the chuck you will see a screw. remove it. put the drill in reverse. hold the chuck. a vice may be needed. pull the trigger. this may work, however in my experience, they are very tricky to get off. I have never had a faulty chuck but have had many faulty gearboxes. i have had to buy ney chuck to fit with the new gearboxes because i couldn't get the good chuck of the damaged gear box. good luck.
SOURCE: The chuck on my old Hilti TE 60 is stripped.
If you can t find the cap nut, drill 2 small holes on either side, tap the holes and put in 2 set screws to hold it in place
SOURCE: how do you remove the bit from the chuck of a TE
Slide the collar on the chuck to the rear (toward the handle)
