Ovens Logo
Posted on Nov 29, 2017
Hello, I need to get hold of a Leisure ZENITH 60 Electric cooker instruction manual for my mum please. I can not work out how to us the timer, an a few other things as well. Could really do with your help in a website perhaps that i could down for free if possible. Any information would be grateful. Thank you. Sandra
5 Related Answers
Anonymous
  • Posted on Apr 07, 2008
SOURCE: leisure rangemaster 55 gas cooker
It sounds exactly the same as I am experiencing on my oven of the same model. My theory is that the full flame gas is controlled by a thermostat, and that this has broken hence why the oven only stays on preheat. This will be a matter of a replacement part. Most likely the thermostat is a bi-metal strip that, because it has heated and cooled so many times in it's life it has simply finally given up. Try searching online for the correct part and get a corgi registered fitter or another suitably qualified fitter to come and replace it.
douglas smith
  • 1462 Answers
  • Posted on Jul 18, 2008
SOURCE: electrolux EOG7330 gas cooker - electric timer fails?
i suspect there is no fault with timer. there is an overheat stat usually on top of the oven but sometimes inside the back. if this detects overheat, then everything is switched off and comes back on after cooled down.
if this is the case, then suspect lack of ventilation causing the overheat or the casing cooling fan failed.
get back to me if i got it wrong
Anonymous
  • 5 Answers
  • Posted on Mar 29, 2010
SOURCE: belling builtin electric cooker formula multifunction double oven think 488BH no instruction book dont know how to use the timer and different parts of fanoven etc.
get manual here
http://rapidshare.com/files/369550394/BellingFormulaMultifunctionDoubleOven.pdf.html
good for 60 days only
Anonymous
  • Posted on Aug 04, 2010
SOURCE: TOER SLOW COOKER INSTRUCTIONS
There should be a middle position where the button sticks out half way at the top and bottom, this is low.
Anonymous
  • Posted on Oct 18, 2010
SOURCE: I need a set of installation instructions
how do i uninstall a hotpoint doubl aven 27 inch wide 50 inches tall chris
Top Ovens Experts
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
john h
Are you an Oven Expert? Answer questions, earn points and help others
