SOURCE: I have a Kawasaki Mule 3000. It is hard to keep
take the spring off the screw and use teflon tape so you can adjust the screw further
SOURCE: kawasaki mule 610 4x4 fuel problem
Check all your fuses and fuel pump relay. Assuming that the pump is in fact installed correctly,and flowing the fuel in the correct direction.
SOURCE: front hub removing
remove the wheel then undo the big nut in the center then remove the brake caliper then remove the big nut and the hub will come off !
SOURCE: what spark plug is right
KAWASAKI MULE 610 XC SPECS
2010-2011 KAF 400 XC (4X4)
Spark Plug BPR5ES
