SOURCE: How do you set the clock/calendar on the Canon MP25DV?
on the bottom of your calculator is a reset button, with a paperclip or a pen press that button. Then, press the calendar, clock key. next, press the equal sign key until the date is flashing type in the date using 11172006. press the equal sign again and the date is set. Next press the calendar, clock key again the time should show up (12-00-00)press the equal sign again until the time starts to flash. enter in the time using 0903 (9:03) press the equal sign again. Time is set. to display the date and time when not using the calculator, press the calculator, clock key 2x's. to go to compute mode press the red CE/C button.
The trick is to hold down the time set button (=) until the time flashes and once the new info is entered, press time set and it will stay. same with the date. You kinda need to play around with it. Thats how i learned.
SOURCE: Setting the Canon MP25DV clock and calendar
press clock/calendar once to set date
1) press equal numbers will flash then use number keys to current time then the X to set am and pm. press = again to set time
2)press clock/calendar until date flashes. use number keys to current date. Press = to set
SOURCE: set the time and date on a canon mp25dv/instructions
To set date:
1. Press the calendar/clock button (display should show date)
2. Press and hold the 'time set' button for 3 seconds (first digit of the date should flash)
3. Use the numeric keys to enter date using mmddyyyy format
4. Press 'time set' button
To set time:
1. Press the calendar/clock button twice (display should show time)
2. Press and hold the 'time set' button for 3 seconds (first digit of the time should flash)
3. Use the numeric keys to enter time using hhmm format, press 'AM/PM' button as needed
The '12/24' button changes between 12 hour and 24 hour format for time.
The 'format' button changes the date format from mmddyyyy to ddmmyyyy or yyyymmdd.
SOURCE: How do you set the date and time?
1) press calendar clock button
2) hold the time and date button for 3 seconds, this button is marked with "Time and Date" one the keypad and not on the button itself
3) The date or time should start blinking
4) make inputs of current date and time
5) press Time and Date button again to save changes
6) All set!
Anytime you want to display the date or time hit the clock and calendar button. The calc will hold the display until u switch to the calculation mode i.e. by pressing the CE/C button.
DUHHHHHHHH!!! All these instructions are in the piddly sheet Canon calls the manual.
