Hey there, I'm Cheri Torres with DISH Network customer service. I came across your questions and wanted to see if I could help. We have a few different codes that you can try in order to get your remote address to your SV TV. I will list here for you the best codes for the 6.4 IR/UHF remote and the instructions for addressing the remote as well. For the 6.4 IR/UHF remote the best codes to try for your type of TV are 901 and 905. I hope you find these codes and instructions useful in addressing your remote to your TV. If you have any further questions or concerns feel free to post back here or you can email me at Cheri.Torres@DISHNetwork.com. Thanks :)
Instructions for addressing your remote to your TV
SOURCE: dish network
Codes for Apex are 595, 618, 743, 744, 005, 006, 019, 020, 120, 745, and 757.
Codes for Sony tv are 500, 514, 578, 640, 670, 690, and 758.
If these dont work here is what is called a power scan. It will go through all the codes in the remote and find the right code for your tv.
1)hold down tv button next to sat button in top left corner
2) when all buttons illuminate press 500 into remote
3)press pound sign
4)Hello, please help..
5)hold town tv button again.
6)when all buttons illuminate press big red power button
7)press up arrow once a second until tv shuts off
8)press # pound sign
9)try to turn tv back on w/ big red power button
10)if tv doesnt turn back on try again from step 2 but use down arrow instead
To set up caller id you have to enable it on the receiver. Press menu 6-1-2, highlight enable and press select. Highlight done and press select. Press 0 three times. Try calling yourself with a cell phone to see if it works, if not, repost on this thread.
SOURCE: need sharp tv codes
The codes for a Sharp are 526, 585, 591, 605, 606, 607, 608, 628, 629. Thanks for using Fix Ya.
SOURCE: Dish Network IR Remote's SAT Mode Not Working ____
Hello, this is Nick Franta with DISH.
If you are trying to get the remote programmed to the receiver you can remove the smartcard from the receiver and that will prompt the system info screen. This will allow you to program the remote to the receiver.
If you need the process for programming the remote, here it is:
Hope this helps!
SOURCE: sv2000 code for dich network
daulton13
I have provided instructions on how to program your remote to your player. Simply follow the instructions below. I have also provided codes for you to try. I hope this helps.
Funai: 500, 527, 532, 541, 569, 587, 618, 640, 657, 677, 679, 682, 694, 733, 756, 758, 777, 781, 783, 795, 797, 798, 829, 837, 838, 839, 841, 844, 846
Address To Other Equipment Using Code
Ray Calo
DISH Network
