Freezers Logo
Posted on Jan 12, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What is the setting for quick cold for the freezer?
Muntejaya Ginting
Level 3:
  • Master 10,422 Answers
  • Posted on Jan 13, 2011
Muntejaya Ginting
Master
Level 3:
Answers
10422
Questions
Helped
2520764
Points
19566
Just set your thermostat to the colder position. If you still face the same problem, you need to conduct service maintenance of your freezer. It may dirty, run out of refrigerant, leaks problem, sensor problem etc.
Frost builts up in the coils
Frost will normally build up if you do not have frost free freezer and in which case it is possible the frost free system is faulty. If it is not frost free then it has to be defrosted a few times in a month. However if the frost comes up very quickly then there are possible causes.
You may be having leakage from the door seals or there are items in the freezer that are not properly covered to avoid moisture escaping. Other possibility is that your freezer is set too cold and there are not many items in it.
1helpful
I have a belling chest freezer BCF 20 ... It has an orange fast freeze switch is this switch left on all the time????
No. That is like running it on "high power" full time and could cause it to wear out and stop working much sooner than it's natural life expectancy. It also uses up more than twice the electricity on your electric bill, than it needs to work normally. That setting could also be used in something like a store, where people open it up every few minutes, to keep it cold when it's opened so often.
That switch should only be used for emergencies, like after a power outage, or to quickly freeze foods that were fully thawed and need to be frozen quickly.
My Freezer is about 11 years old. There is moisture coming from underneath the freezer and it is not keeping things cold enough. The freezer has a "Quick Freeze" setting that seems to work, once...
Usually if a refrigerator is holding water this means that the condensate from the freezer is not going down into the pan in the bottom, the water has to go somewhere so it ends up in your refrigerator. Find the drain line in the bottom and try some how to blow it out, if you can do this and clean the pan you should be ok.
Will not quite get to freezing.
check warranty quick
Oct 09, 2009 • Freezers
2answers
Alarm goes off and freezer not cold
The light indicates the need for a new battery (9V)
Maytag fridge getting too cold
what happens when set on the warmest setting? still too cold then I'd think it was the thermostat. Good luck
Jul 03, 2009 • Freezers
1helpful
Frigidaire upright freezer Model #FFU17C3AW1 Not keeping cold
Yes that is the correct part number.
If a new cold control does not correct the problem. Replace the compressor start relay.
2answers
Hoshizaki ice machine repair?
seems that its low on water or float switch is bad. try to clean float
1helpful
POWER LIGHT FLASHES ON / OFF
You need to install or change the battery for the power out freezer alarm. Mine was just doing the same thing. I looked on the web for the answer and couldn't find it. Opened the door to look for the model number and there was the diagram for the light flashing codes. Mine's battery compartment is in the grill on the bottom (right below the door) on the left side. Takes a 9v battery. I had a power outage recently and it must have killed the battery after beeping for several hours.
Top Shelf of Freezer Not Cooling
sounds like you may have a refridgerant blockage in the system. it may need a regas to see if it can be unblocked, as this is not a quick job it may cost you but phone around on the cost/feasibility of it. it may be just as well to get a new or second hand freezer.
Top Woods Freezers Experts
ADMIN Andrew
ADMIN Andrew
Kardoc
Are you a Woods Freezer Expert? Answer questions, earn points and help others
