KitchenAid KHHS179L Convection/Microwave Oven Logo
Posted on Jan 10, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Is it worth to fix if not heating? - KitchenAid KHHS179L Convection/Microwave Oven
Anonymous
Level 3:
  • KitchenAid Master 43,501 Answers
  • Posted on Feb 22, 2011
Anonymous
KitchenAid Master
Level 3:
Answers
43501
Questions
0
Helped
11051790
Points
101587
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Worth fixing HVM1540DN1ww?
most probably main transformer fuse blown. if fuse is ok & supply is ok on transformer input terminels.then replace magnetron
MICROWAVE DOESN'T HEAT
If it powers up but no heat, the magnetron tube went out. Not worth fixing unless under warranty.
My microwave stop heating what could it be is it worth fixing
The magnetron is gone, or the inverter board, "if 7 years old or less" To answer your question, not worth fixing, cheaper to buy.
GE Spacesaver Microwave not heating, inside fan not working
I suggest you have the microwave oven replaced, the prices have dropped considerably for the last several years and you have got your money worth out of the unit.
1helpful
The microwave not heating the food ck fuse ok
If the microwave is not heating and isn't caused by it being in a strange mode then this usually means that either the magnatron or the power transistors have failed. Either of these are repairable but the repairs are not that cheap. So the repairs can cost more than a new microwave. The power transistors are worth about $5 and then you might get charged say $75 for labour. So the question then is if it is cheaper to fix it or replace it with a new one. If you have a higher end one that is worth more then it can be worth fixing. If it is a lower cost unit then just replace it. Get an repair estimate first and know what a suitable replacement costs and use that as your guide for what to do.
You can find appliance repair shops either from stores or contact Kenmore(Sears) to see if they have a repair depot near you.
2answers
Hums, does not heat when started. Display, timer,
The problem could be the high voltage fuse or the magnatron assembly. replace both to be safe. good luck.
4helpful
GE Spacemaker Microwave XL1400- No heat
The problem could be anything from a defective control circuit board or a burned out magnetron tube. Either fix is quite expensive and you'll have to evaluate whether you think the repair is worth the cost vs buying a new microwave.
Bear in mind that a fixed microwave is still a used microwave. So to get an apples-to-apples comparison you have to ask yourself, would I pay $XXX (substitute XXX's with actual repair cost) for my used microwave?
Will not heat
Magnetron probably the cause, not worth fixing in most cases. You are better off buying a new microwave because the cost of fixing isn't that much better than buying a new one usually.
Benjamin
Top KitchenAid Microwave Ovens Experts
john h
SmartAviator
SmartAviator
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
