I have a Compaq presario 2580us that has an issue with the keyboard. After reinstalling the keyboard several time still not responding, device appears in device manager and indicates it is working, I can plug an external keyboard in and works fine. the keyboard (pad) is brand new. I have sought out latest drivers but no success yet, an ideas?
In advance,
Thanks
Richard
Key board dead , correct. ? even the caps lock key will not toggle its led.
my guess is you bought a clone keyboard from china, on fleabay
and its dead. as many are, some are wired wrong.
the ribbon cable on mine fits to a special connector that likes to break easy, is your broken this locking jack there?
is it plugged in upside down?
why did you buy a keyboard. was the other dead.
when did the keyboard fail. list week last year, or never
i bought it for cheap with dead kbd....
there is no HP drivers, HP retired this old PC, after 10 years.
so what makes you sure your non HP drivers are any good.?
NO OS stated, not even a clue. XP?
what I'd do , us boot to a Knoppix v7 live boot(dvd/usbstic)(linux)
if the keyboard fails NOW, then its bad KBD. or the jack cable or connector there, (or inserted wrong) or damage. there.
buffer chip is blown up with ESD events. (electrostatic discharges)
is the keyboard dead in BIOS
on ours we hit ESC or F10 and BIOS screens pop
power on hammer ESC or F10 or what the screen tells you to hit.
the go in to BIOS screens, now test the keyboard.
using say the arrow keys to navigate the BIOS menus
if the ESC and F10 key are dead that is a bad keyboard.
what must work here is the electronics.
SOURCE: Compaq Presario 2580US Keyboard
Sounds like dirt or some spilled soda.
-- Had the same problem after an OJ spill. --
If you feel comfortable about removing the keyboard, disconnect all the wires and cables, then kive the keyboard a thorough washing. Then let it dry overnight.
If that doesn't sound like something you want to attempt, then you will have to take it in to a computer shop.
SOURCE: Memory Upgrade for Compaq Presario 2580US
no 'coz these two memory card differ in size and slot especially when the mainboard doesn't support ddr2
SOURCE: laptop pad not responding at all
Make sure that the drivers are installed for the pad. Also check and make sure the pad is turned on in the BIOS. You also need to make sure you have the software installed that allows you to toggle between the two.
