Maytag MGC5430 Gas Cooktop Logo
Posted on Jan 05, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I need 4 replacement knobs and I cannot find them!! Please help
Kelly
Level 3:
  • Maytag Master 3,740 Answers
  • Posted on Jan 05, 2011
Kelly
Maytag Master
Level 3:
Answers
3740
Questions
Helped
2226279
Points
12091
Hi and welcome to FixYa, I am Kelly. I am assuming that your model number is MGC5430 as listed in your post. If not use this link to find them by entering your model number:
(just note that there are 2 to 5 digits missing from your model number)
http://www.appliancepartspros.com
See this page:
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=MGC5430
It brings up the following models:
I need 4 replacement knobs - arrow_link.gif MGC5430ADB SURFACE UNIT- GAS arrow_link.gif MGC5430ADC SURFACE UNIT- GI need 4 replacement knobs - arrow_link.gifg src="/uploads/images/arrow_link.gif" alt="arrow_link.gif" class="h_mi" /> MGC543I need 4 replacement knobs - arrow_link.gifSURFACE UNIT- GAS arrow_link.gif MGC5430ADW SURFACE UNIT- GAS arrow_link.gif MGC5430BDB SURFACE UNIT- GAS arrow_link.gif MGC5430BDB20 36`` GAS COOKTOP arrow_link.gif MGC5430BDQ SURFACE UNIT- GAS arrow_liI need 4 replacement knobs - arrow_link.gif MGC5430BDS SURFACE UNIT- GAS MGC5430BDS20 36`` GAS COOKTOP I need 4 replacement knobs - arrow_link.gifuploads/images/arrow_link.gif" alt="arrow_link.gif" class="h_mi" /> MGC5430BDW SURFACE UNIT- GAS arrow_link.gif MGC5430BDW21 30`` GAS COOKTOP
I used the MAYTAG MGC5430BDB20 as a reference and the BLACK knob is item 6 this link: http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5515609&diagram_id=28426062#d28426062 Detailed view is here: http://www.appliancepartspros.com/part_details.aspx?part_id=4100044 If you need more assistance please respond with a complete model number and I will use other sources to loate your knobs. Thanks for choosing FixYa, Kelly
We have a ge cooktop (gas). even though the knobs are turned off , we can hear "tick tick" noise from one of the burners.
Unplug your cooktop for 24hrs and retest. Sometimes moisture gets into the switches under the knobs and can cause a short. If this continues after you let the unit dry out then your will need the replace the switches/or switch harness.
Hope that was helpful please rate me a "4" if that helped.
Dec 13, 2010 • GE Cooktops
1helpful
I have a Chef 4 burner gas cooktop probably at least 10 years old. I need to replace 3 burner knobs. One works fine. Where can I find replacements? I live near Perth, Western Australia.
In the US, there is a parts distributor with locations all over the country. Their number is 1-800-482-6022. They have four of your burner knobs (part number 74001253) in stock in the Fresno, California warehouse. The cost per knob is $9.27 US. I can't say how much the shipping would be, but they use UPS and FED EX.
Good luck....and good day.
I need new knobs for collonial green creda gas hob tried internet 20 each can i use a cheaper black one. i need four
you can use any knobs that fit the shafts/ creda is very expensive . robert shaw has replacment knobs . but make sure the shaft size is correct . if its gas the standard ( D ) style will work .. mm cost afout 19.00 for a set of 4 .. mm
Jul 07, 2010 • Cooktops
3 of 4 knobs do not compress to turn on gas
You must replace those controls. Cleaning or loosening them up would be temporary at best and the next time they stick it could be in the open position. Safety first...Eric
Where in VA do you get replacement rings for DACOR SGM365S burner knobs. These are the rings that go around the control knobs?
Appliance Parts Depot in TX. Look it up. Please contact me if you need further help and leave feedback. Thanks for letting me help you!
DACOR SGM365S 5-Burner
Appliance Parts Depot in TX- look them up. Please contact me if you need further help and leave feedback. Thanks for letting me help you!
Fan Switch broke off Jenn-Air CVE3400 Radiant Cooktop
I am wondering if you just need to replace the knob then perhaps you don't need to take much apart.
Is this a knob that has an allen screw in the side that unscrews to let it come off or is it a friction fit.
If the knob is so small that you can't get it off some times wrapping a thin rag around it gives you the way to tug it off. If it is the whole switch you are fixing then I see why you need to take lots of things apart. If found the installation manual online and that might give you a clue to how it is installed in the counter to take it back out if you need to get to the insides. I am not sure what you need help with so please let me know more if this was not enough.
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=CVE340&siteCd=JA_EN_US
Dec 12, 2007 • Cooktops
2answers
Smeg SE64 Gas cook top
problem with hob is probably water ingress in area of ignition unit - will probably cure itself oven is a completely separate unit from hob. problem with it is that you have to re-set the clock - you have it on automatic. after power outage, oven clock always has to be reset
Top Maytag Cooktops Experts
gerbee gomez
Paul Carew
Are you a Maytag Cooktop Expert? Answer questions, earn points and help others
