Electrolux EI30MH55GS Microwave Oven Logo
Posted on Jan 05, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I replace the touch pad - Electrolux EI30MH55GS Microwave Oven
Anonymous
Level 3:
Brigadier General:
  • Master 8,909 Answers
  • Posted on Jan 05, 2011
Anonymous
Master
Level 3:
Brigadier General:
Answers
8909
Questions
Helped
1573516
Points
28391
It looks like the panel is stuck on, much the same as uk microwave ovens and the flexible pcboard is fed through a slot behind the panel.
If the new one is at hand, that will show you exactly how to replace it.
Touch pad inoperaive
Unfortunately, if you are having problems with a touch pad you will probably have to replace either the touch pad itself, if you can get it or the whole control board and touch pad as a unit which normally ends up running as much as a new microwave. I would check your warranty and see if it still is covered and proceed that direction.
Touch pad on front panel is not working.
REplace the touch pad. The touch pad is more likely to have failed rather than the control board.
Touch pad inoperaive on one side
about the only thing you could do is to replace the touch pad there are no repairs done to touch pads we basically just install a new one i suppose one could take one apart and try to fix it but there are no schematics that they give to the touch pad make sure before ordering a new touch pad that it is the touch pad and not the control board that has malfunctioned if you are unable to perform these tests please call a repair technician if you have any further questions please message me back and please remember to rank how this opinion has helped in your appliance situation Thanks again
Rick
F2 E0 "Stuck key" ????????????
F2-E0 - Shorted Touch Pad (Keypad) - Check the connection between the touch pad (keypad) and control board (clock) to make sure it is secure.
Select the 'cancel' function and wait 60 seconds.
If error code reappears then replace the touch pad, or touch pad and control board (clock) if all one assembly.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!^!^
1helpful
I have a Magic Chef microwave model mco153sf. The
HI. This is , indeed, an issue within the touch pad circuitry. it is damage, and will require replacement. I have located a replacement touch pad. Use the link below to access the touch pad. You can order the pad on-line, by clicking the link below.
CLICK HERE
The touch pad does not work. It displays menus
HI. this damaged touch pad board should be replaced asap. the board itself is not repairable.
Replacing the board will fix the issue.
5helpful
Microwave shows F2 on display with controls non functional
HI. this is a code that represents a failed key pad or touch pad membrane board. replacing this failed touch pad will fix this issue. This touch pad board is separate from the actual control board.
4helpful
Touch pad does not work, clocke does, nothing else works
Hi this will happen when the touch pad circuits become unstable and damaged, due to abundant usage or , old age.
simply replacing the touch pad will fix this issue.
Top Electrolux Microwave Ovens Experts
Paul Bade
ADMIN Andrew
ADMIN Andrew
Are you an Electrolux Microwave Oven Expert? Answer questions, earn points and help others
