Ou should disconnect and reconnect the USB cable at both ends to
ensure there is a secure connection on the device side as well as the
computer side. (Refer to the illustration below to confirm the USB cable
is in the proper orientation.) It may also be necessary to try a
different USB port on the computer. Additionally, you may need to
disconnect other USB devices, temporarily, in order to determine if a
conflict exists.
Note:
Some printers have a type-A USB receptacle on the front to connect
directly to a digital camera. The type-B receptacle, on the printer,
will connect to the type-A receptacle on the computer with an A to B USB cable. Icon on USB Cable Shape of the USB Connector Incorrect (A to A) USB Cable
There
shouldn't be any resistance when connecting the USB cable to the
device. If the cable does not easily slide into the device's port, look
at the end of the connector. The shape of the connector should match the
port on the device.
Note:
All USB cables will have a USB icon on one side. The side of the cable
where the icon is situated is different than the other three sides.
error code = 6A00 whats the problem - usb_cable_straightview.jpgsrc="/uploads/images/usb_cable_straightview.jpg" alt="usb_cable_straightview.jpg" class="h_mi" />
