SOURCE: Canon ImagePress C1 error E000747-8000
E747 from what I remember is the connection cable from either the scanner to the print device, or scanner to the copier. Make sure that none are loose and they are in the correct slots.
Mismatching the cables may result in the error.
SOURCE: my canon pixma mp830 shows error code 5010. what
The scanner lock switch may be in the locked position. Lift the cover and check the slide switch located on the top front left. If this is not the problem, you will have to have a service center look at the problem.
SOURCE: I have a canon mx700 & have an error code 6A80 -need help
That error says there might be paper scraps stopping the purge assembly on the right where the printhead parks, or something fallen into the slot where paper goes stopping the paper feed assembly. You just have to inspect closely with a flashlight before taking to the shop.
SOURCE: canon imagepress c7000vp error code
The laser shutter is faulty. The laser unit is faulty. The potential measure
