SOURCE: how to remove the stand from samsung LCD TV
Place the tv on its screen flat on a soft surface,
you need to remove all the screws, not just the stand one marked.
Lift the back panel and then you will be able to slide down the stand, when you have removed the back cover you will also see where how your wall mount will fit to the chassis.
Place all the screws back on the back lid.
SOURCE: Remove stand
if the screws won't come out, then get a magnet, the small kind that is used in auto mechanics, that's what I use to finish pulling them out, or use a magnetice drill bit, but that's all that is holding the stand on
SOURCE: samsung LN37b650 television stand removal. how do
Mounting on the wall, be sure use the short screws and no power tools. Hopefully it can help you and get a good commend.
SOURCE: how do i remove stand from samsung syncmaster 2333
its a snap-type plug-in stand, just hold the stand firmly and pull the monitor equally upward, then it will snap quickly....... but a proffessional reminder! Before mounting your SyncMaster on a wall, be sure to plug the two (2) stand holes located at the buttom of the monitor. My Samsung SyncMaster 2333HD LCD TV was twice intruded by adult-size lizard, both incident resulted to main power board damaged!!!!
SOURCE: Small Crack on the screen and the 58 inch plasma
The screen needs to be replaced if it is cracked, usually it is not economical to repair, but it is worth getting a quote.
