Verbatim HP Intel Xeon Quad-Core E5345 2.33GHz - Processor Upgrade (436013-B21) Logo
Posted on Dec 29, 2010
How I can overclocking a xeon e5345 ? - Verbatim HP Intel Xeon Quad-Core E5345 2.33GHz - Processor Upgrade (436013-B21)
2answers
Can run windows 8 on IBM intellistation z pro ?
IBM IntelliStation zPro came with different CPU chips through 1997 to 2006. Depending on which year or type your machine is will determine if you can upgrade to Windows8.
The chips used were
IntelliStation Z Pro
Type 6899 (March 1997 to ??)
Type 6865 (October 1998 to April 2000)
Type 6866 (January 2000 to March 2002)
Type 6894 (May 2001 to June 2002)
Type 6221 (November 2002 to February 2005)
  • Dual Intel Xeon at 2.4, 2.67, 2.8 or 3.2 GHz
Type 6223 (August 2004 to March 2007)
  • Dual Intel Xeon with Intel 64 (formerly EM64T) at 3.0, 3.2, 3.4, 3.6 or 3.8 GHz
Type 9228 (June 2006)
  • Dual Intel Xeon Model 5130, 5140, 5150 or 5160
Windows 8 If you want to run Windows 8 on your PC, here's what it takes:
  • Processor: 1 gigahertz (GHz) or faster with support for PAE, NX, and SSE2 (more info)
  • RAM: 1 gigabyte (GB) (32-bit) or 2 GB (64-bit)
  • Hard disk space: 16 GB (32-bit) or 20 GB (64-bit)
  • Graphics card: Microsoft DirectX 9 graphics device with WDDM driver
As you have Type 6223 which a Xeon faster than 1GHz it should work with Windows 8 but not all Xeon processors are compatible depending on which one you have. See this Microsoft site after you check your Xeon chip family on the motherboard or through the Windows system command. Search for xeon.
Processors What processors support Windows 8
Just built new computer using an ASUS Z8PE-D12 motherboard. When I power it up, it keeps wanting to flash the bios. I just had to replace an identical motherboard doing the same thing. Removed all...
z8 is nice, I know for sure,
Z8PE-D12 the dual xenon server grade mobo, like my z600 works station has but HP made.
let me guess both boards never worked for you and you bought them on fleabay, and are DOA? that it, what is the story here.
Let me guess more, (no history at all)
you just put in a new CPU, xeon, ?
well if you did and
1: it is not support, it will do that.
2: or it needs flashed bios to support newer xeons.
3; no you can not run all xeon's made in this mobo ever.
first off put only one xeon the primary socket.
and only ram for just it.
then at ausu we site makes sure you are using the right xeons first.
the correct path is with working xeon, flash the bios.
then upgrade xeons last.
ok?
5500 series processor
1366 socket
Six-Core/Quad-Core Intel® Xeon® X5600 Series (130W)
Six-Core/Quad-Core/Dual Core Intel® Xeon® E5600/E5500 Series (80W)
Quad-Core Intel® Xeon® W5500 Series (130W)
Dual Core/Six-Core/Quad-Core Intel® Xeon® L5600/L5500 Series (60W/40W/38W)
Six-Core/Quad-Core Intel® Xeon® X5600/X5500 Series (95W)
here is the offical list.
newest BIOS is 1401
i bet yours is super old bios and not stated, or what xeons you have.
as you can see it is not trivial this topic.
https://www.asus.com/Commercial-Servers-Workstations/Z8PED12/HelpDesk_CPU/
it seems owning just 1
Dual-Core Intel Xeon E5502
as cheap as $5 60 on fleabay will allow flashing this mobo firmware, worst case.
Dear sirs, I would like to upgrade the cpu`s of my Compaq Evo W6000 PC with the Motherboard Model 06D0h. Please let me know what are the strongest cpu`s I could use. Many thanks Murat
I suggest this to you.
Intel Xeon Processor, 1.4 GHz/100.0K
Intel Xeon Processor, 1.5 GHz/100.0K
Intel Xeon Processor, 1.7 GHz/100.0K
Intel Xeon Processor, 2.0 GHz/100.0K, L3
Intel Xeon Processor, 2.2 GHz
Intel Xeon Processor, 2.6 GHz/400
Processor, 1.8 GHz, 603FCPGA
Processor, 2.0 GHz, 603FCPGA
Processor, 2.2 GHz, 603FCPGA
Processor, PRST, 2.4 GHz/400, INT 261668-004 284645-001 source: ftp://ftp.compaq.com/pub/supportinformation/technotes/evo_w6000_workstation_rev6_us.pdf
2answers
I have a intel dg31pr motherboard with e7200 processor.i want to overclock it.plz help me............
Overclocking is something you should only do if you are fairly experienced with computers. Most motherboards that overclock are made for overclocking as are the processors used. Good overclocking requires a balance of increased FSB, multiplier, increased voltage to the ram and sometimes the processor as well, and excellent cooling. It is easy to burn out your system by overclocking. There are many things you should know first. For that reasion alone it is impossible for me to tell you how to overclock it.
But, go to www.extremeoverclocking.com. This is a site made for people who want to overclock. Read and browse through the forums. You will also find some excellent by the numbers guides there. Sigh up and jump in. When you perform your first overclock, come back and tell me. I've been overclocking since 2002.
Sirwriter
Overclocking
Overclocking is set from the BIOS configuration. Not all BIOS allows overclocking, it may need a BIOS upgrade.
Check the ASUS WEB site for your model motherboard.
Overclocking the CPU (ie running at a higher clock speed) and increasing Frontside bus speed will give better performance BUT there is a downside too, if you overclock too high you could overheat the CPU and it could fail.
Dual E5345 Xeon -Upgrade?
Hi there.
If you note down the make and model of the motherboard you will be able to check to see if you can upgrade to better processors and which type of processors the motherboard supports.
If you want me to source the info please post the make and model of the board.
Thanks for using FixYa!!
2answers
Overclock an Intel E6300 on a GA-8I945GZME-RH motherboard
You need to check your BIOS. If you can overclock you will see a selection for CPU and speed in BIOS. If not there then your motherboard does not allow you to overclock your CPU.
Rate this solution.
Overclock xeon 2ghz
go to server world .com
Overclocking
are you sure that your pc is built for overclocking? dont be risky it might get you trouble on your pc. i suggest that you shouldnt overclocking it and besides your processor is high ed.
CHARCOIS
Top Verbatim Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Sudeep Chatterjee
Sudeep Chatterjee
Are you a Verbatim Computer and Internet Expert? Answer questions, earn points and help others
