Just something to try: On the control board you will find a connector block for your central heating pump. Its your normal brown and blue wire ples yellow green earth and is clearly marked 'pump' Disconnect it and see if it solves the problem? If it does you may need to replace the central heating pump. When I ought mine the movers just cut the wire and it shorted.
Hello there. I have the same problem. Did you ever solve your problem with the Rayburn tripping out the sockets?
