Things You'll Need:
the window. Select the CD-ROM (ISO) icon and click on the "ISO" tab to
configure for your data files. If you are going to create a CD that will be used on
Windows 95/98/ME/2000/XP or NT, use the below settings for best results. Once you have made these changes, click on NEW
have
selected My Documents for the folder to store this file too. Then name
the image, for example 'DataCD_1', and click the Save button
Note: Click on the drop down menu to navigate thru folders and drive letters. Select
the folder/drive that you would desire to store the image file too.
Note: Type in a file name of the image. And note what directory it will be saved in for later use.
Right-click on Drive A. You will see the option to format the drive.
Click on Format. Depending on your operating system, you will see an option that reads either "Create a system disk" or "Create a MS Dos system disk." Click the box next to this option.
Click the "Start" button to begin formatting the disk.
Open the software that you use to burn or write files to the CD-rom or DVD drive.
Click on "Make a Data CD or DVD." Insert a blank CD-R or DVD-R disk into the drive.
Look for the option to "Make this disk bootable." You may have to scroll over the various icons displayed to find this option. Click on the option.
Burn the CD or DVD as usual. Once completed, this disk can be used to boot your computer.
When completed, you will have a bootable floppy disk.
For CD Rom or DVD disks
hope this helps
