Jacuzzi 6800-959 Nova 6 Whirlpool Bath 6'- White Logo
Posted on Dec 24, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a Nova 6 jacuzzi whirlpool jetted tub. The magic control air switch will not work. If I remove the side panel and disconnect the small air tube a small puff of air will both turn on and turn off the tub. Where can I find instructions on where to purchase a switch, how to replace this air switch, and is there a repair service in Salt Lake City, Utah. Thanks
US Parts Center
Level 3:
  • Jacuzzi Master 719 Answers
  • Posted on Feb 13, 2013
US Parts Center
Jacuzzi Master
Level 3:
Answers
719
Questions
0
Helped
290146
Points
1972
The Magic Touch system has been discontinued by Jacuzzi Whirlpool.
You will need a new air switch kit.
Rod
US Parts Center
888-521-6183
5 Related Answers
co7196
Ned C Cook
  • 3433 Answers
  • Posted on Jul 29, 2009
SOURCE: smells like somethin died
Pour some chlorine bleach , not alot.in and let it circulate. You may want to clean the filter first.You are smelling a real dirty filter.
Alan
  • 80 Answers
  • Posted on Sep 28, 2009
SOURCE: jacuzzi whirlpool hot tub, flashes Fl-1 has new filters,
Sounds like a bad heating element. This is located in a stainless steel tube under or around the main control box behind the cover around the tub. It is not hard to replace but should be done by a pro. The part is avaliable online.
Alan
  • 80 Answers
  • Posted on Mar 26, 2010
SOURCE: My jacuzzi tub motor will hum but does not run. I
If the motor hums, it is seized and needs to be replaced. Call a reputable repair tech to make the necessary repairs.
Anonymous
  • 16 Answers
  • Posted on Mar 27, 2010
SOURCE: No heat with Rapid Heat U395000 Jacuzzi jetted tub
when you changed the heater did you make sure you also changed out the temp sensor cause most of the time calciun builds up an is the reason for both the heater an sensor to fail calcium is ok at temps above 93.6 degrees but as soon as the temp drops below this point it will come out of solution an start to harden on the element an sensor.Always make sure to that you are getting power from the spa pack to the heater check for voltage at the main leads on the heater just because it says its on does not always mean you are getting power to the heater.Always remember with spas the problem lies where the power dies.sometimes it can even be your main top side controls they can go bad an indicate the heat is on but will not relay that to the heater.make sure you got the correct kilowatt heater also an that you have the correct one in terms of 240v or 110v also from the thousands of heaters i have replaced in spas over the years i always check to see if i am getting the correct omhs reading before i install them should be around 8-10 for a 110 an 12-13 for a 240
uspartscente
US Parts Center
  • 719 Answers
  • Posted on Sep 06, 2010
SOURCE: RapidHeat In-Line Heater U395000 [ Bathtubs and Whirlpools,: My jacuzzi tub jets run for ONLY about 5 minutes b...
you have a bad motor - when a motor overheats there is a sensor inside the motor that will shut if down so as to not damage the windings and such. once your tub has cooled down for 10 mins or so it will turn back on. the fact that you can push the button multiple times just means that you are turning the air switch on the back of the motor on/off until you get to the point where the motor has cooled down and will turn back on. if you do not push the air button after the tub shuts down and you finish your bath then when the pump cools down it will come back on because the air switch in the motor is latching i.e. it is either on or off. Since you left it in the on position the motor will come back on once the motor has cooled down.
Top Jacuzzi Home Experts
john h
vince
Are you a Jacuzzi Home Expert? Answer questions, earn points and help others
