Posted on Dec 22, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Error 007 - Canon ImageRunner 2016 Copier
Anonymous
Level 2:
Scholar:
  • Expert 78 Answers
  • Posted on Dec 22, 2010
Anonymous
Expert
Level 2:
Scholar:
Answers
78
Questions
0
Helped
43425
Points
286
Error code E007
Detail code 0000
Fixing film sensor failure
The fixing film sensor is faulty.
- Check the connector of the fixing film sensor.
- Replace the fixing film sensor.
- Replace the DC controller PCB.
8.2.1.1 Controlling the Fixing Film Speed
The rotation cycle is measured with reference to the mark provided at the end of the fixing film to rotate the fixing drive motor at the optimum speed, thus keeping the paper feed speed constant. Measurement of the cycle of each rotation (excluding the initial rotation and post-rotation) of the fixing drive motor starts when 1 second lapses after the motor starts rotating and ends when the trailing edge of the last sheet has passed through the fixing nipper.
2answers
Xerox Workcentre 7345. What is fault code 007-282 please?
The Tray 3 Level Sensor does not detect that the Tray has lifted.
Possible solutions:
Examine the trays and paper feed assemblies.
Power off the machine, check the MSI Tray for any obstructions, and power the machine back on with Tray 6 opened. Then close Tray 6 when prompted.
Your tray may be stuck or there could be a sensor malfunction. Power off the machine and then power it back on.
Error codes for 7300 007-277
Sounds like a hardware issue:
Error 007-277: Tray 4 Paper Size Sensor Broken (TTM)
2answers
Error code 007 340
Hello!
This issue relates to an error with the PHD (Photoconductive) Unit. To resolve this error please try the following steps:
1. Turn the printer off.
2. Wait 10 seconds.
3. Turn the printer on.
4. Determine if the issue still occurs.
5. If 007-340 or 007-341 Restart Printer Error recurs please remove the PHD Unit and remove any packaging.
To Remove PHD Unit:-> Remove the Paper Tray
-> Open the front cover.
-> Put a piece of paper on the transfer belt to protect it from scratches and from light damage. Do not cover the left and right of the belt guards with the paper.
-> Rotate the four stoppers of the PHD counter-clockwise 90 degrees to release the locks
-> Remove the PHD unit toward you by pulling it by the left and right handles.
-> Lift up the PHD unit from the printer. Be careful to avoid scratching the transfer belt.
-> Remove the packing tape by pulling straight out
Reinsert the PHD.
-> Close the front cover.
6. If error recurs with the PHD Unit re-seated please try another PHD from a working 2130CN Laser Printer (if available).
7. If issue recurs after trying another PHD or no PHD Unit is available, please call Dell Technical Support to advise.
Panasonic viera tv. Connection error 007
My TV set is PANASONIC VIERA 32AS600 series. Received error 007, canot connect to wi-fi network. In wi-fi settings, change to MANUAL, check proxy settings: delete all letters/characters in proxy address (leave blank), proxy port is not critical. Check your connection. Good luck !
Error code 007-2913
Welcome to Fixya. You can refer to the link below about the error code.
Error 007-2913
Thanks
What does TCR error code 007 mean - wheere can I find a list of error code expalnations. Online manual no help
This error code 007 means that there is a line fault could be the fax you are sending to, Plug a phone into your skt & test to see if line is crackling.
System error E.007
Hi, are you sure that you have clc 1140 Copier? Because E007 isnt clc 1140 error code. These error code is related to machines with teflon folie, in newer date b&w copiers.
These error means that copier cant see fixing folies mark, and only that you can do is to replace fixing film ( folie ).
1helpful
2answers
Dell error 007 371.How to solve or reset this problem ?thanks
http://support.dell.com/support/edocs/software/dtk/2.4/CLI/pdf/dtk24cli.pdf look here codes are posted
Grand Canyon Tech
Grand Canyon Tech
Sudeep Chatterjee
Sudeep Chatterjee
