Zodiac Baracuda G4 Automatic Pool Cleaner Ne221 Logo
Posted on Dec 20, 2010
I would like to remove the standard wheel deflector from my new Zodiac pool cleaner and replace it with a larger one which i have already purchased, without damaging machine or wheel. REASON: The zodiac is getting stuck in a tight corner at the base of the pool and the first step.
Anonymous
Level 1:
Problem Solver:
  • Contributor 16 Answers
  • Posted on Dec 29, 2010
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
16
Questions
0
Helped
5612
Points
31
It comes off, just not easily. You want to pull up with more pressure being put on one side so you allow the "teeth" holding it on there to start to come lose. Then it will come off. If you can't do it a pool professional should be able to do it for you.
John McCaffrey
Level 1:
  • Contributor 2 Answers
  • Posted on Oct 23, 2011
John McCaffrey
Contributor
Level 1:
Answers
Questions
0
Helped
2122
Points
5
I used a regular flat screwdriver -- inserted under each tooth and bent up. They take a surprising amount of bend without breaking. Just bend each tooth in turn all the way around -- then it is easy to pop off.
Top Zodiac Pool & Spa Experts
john h
ADMIN Andrew
ADMIN Andrew
Anonymous
Are you a Zodiac Pool and Spa Expert? Answer questions, earn points and help others
