Please help me figure out why my Hp PCS 1410v won't scan
You can use Image Zone software which comes with HP PSC 1410. There are problems sometimes getting this to work on Vista.
The other option is to have a program such as Picassa which allows you to import from camera scanner etc.
I have used this succesfully.
SOURCE: Scanner
Check the power and the data (USB) cables in the printer...check both ends...
Check :-
# The printer powers on properly
# There also can be problems with the printer driver
# and also internal printers....
Try reinstalling the printer driver...
<PLEASE RATE ME AS FIXYA>for my help......................
I'm having a similar problem, only I can't get my computer to register the scanner at all. It keeps shutting of the HP Digital Imaging Monitor program and saying it can't connect to the scanner. I do have Vista. Please help!
I am having the same problem and use an iMac.
I'm not sure if I need to update software. I think I remember getting a message about that awhile ago -- which I ignored, because I didn't have time to insall, etc. etc. We also have a mac, and a Mac Airport which we have our printed connected to wirelessly. I don't know if that is causing the problem in some what, but someone please let me know if they find a way to troubleshoot. Thanks!
My scanner is not scanning. It has worked perfectly in the past. When I push "scan" the ON/ RESUME light blinks green, however does not scan??
can't get scanner to work
The scanner will not connect!
i have tried everything and my hp psc 1410v will not scan, the green light just blinks and then nothing else happens, i have cleaned it, shut it off/on but nothing. HELP!!!
I am having the same problem. The resum lite blinks and nothing scans. What do I do?
