Epson Stylus Photo 890 InkJet Printer Logo
Posted on Jul 02, 2008
My printer has ink and it wont print it feeds through and sounds like its printing but nothing is there
  • 2 more comments
  • Anonymous Jul 02, 2008
    I have canon prixma ip 2000 my printer has ink but does not print. only red color is printed.
    I have changed my cartridges. done maintance by deep cleaning and nozzle check more than three times
    same problem i have changed the cartridges and did deep cleaning and nozzle cleaning
  • alisonprid Jul 21, 2008
    yes I have the same problem - my printer makes all the right noises and the pages come out blank.
  • Anonymous Aug 14, 2008
    Repoaced both cartridges and tried all the cleaning nozzles and tests but paper feeds through, sounds as if it is printing but paper is blank.
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Aug 14, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
459
Points
What does the print head look like?
A
Anonymous
You can try this.
OK, Canon will hate me for posting this.
1. Remove ink cartridges
2. Remove print head
3. go to sink or tub (stainless steel, not plastic type), pick up a roll of paper towel on the way.
4. Fold several layers of paper towel and place on flat surface.
5. Run hot water until HOT!
6. Turn hot water back to a dribble.
7. Run the dribbling hot water through print head, be careful not to wet the gold contacts.
8.When water running through print head is clear, place print head on paper towel.
9. Repeat number 7 and 8 until no colour shows on paper towel.
10. Gently DAB print head (DO NOT WIPE) inside and out with dry paper towel until dry.
11. I normally replace print head after drying, but you may wish to let it air dry overnight.
12. Replace print head in printer and install cartridges
13. Start printing.
I do this to all 4 of my Canon printers every 6 months or so.
If any colour fails to print after this process it means your print head probably needs replacing.
1 Related Answer
Anonymous
  • 353 Answers
  • Posted on Feb 01, 2009
SOURCE: Epson Stylus C66 inkjet Printer does not print !
Have you tried a cleaning cycle? If not, try one. Now run a nozzle check using the status monitor (right click the little printer icon in the bottom right corner of the screen and select nozzle check). Is there any sign of ink on the paper. Try up to three cleaning cycles. If ink is now flowing, but not yet perfectly, don't carry out any more cleaning cycles. Just leave the printer for 24 hours (to allow any air in the print head to disperse). Then repeat the cleaning cycle/wait process. It may take a while to restore a perfect nozzle check print. If these actions produce no positive results, report back.
Top Epson Office Equipment & Supplies Experts
Rommel Balcita
Grand Canyon Tech
Grand Canyon Tech
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
