Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator Logo
Posted on Jul 02, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Error Code Er FF
This is the Error Code listed on the display panel of our Kenmore Elite Trio Model 795.7756. The code appeared after the refrigerator was pulled out from its space for cleaning.
  • 1 more comment
  • k3jlee Aug 05, 2008
    We purchased our refrig about 1 1/2 years ago and had nothing but trouble every since. Display shows ER FF, we unplug it and replug it and it works correctly for about 4 hours than displays ER FF again. This is the 2nd thing to go wrong with this in the last 1 1/2 years. (Ice maker went out twice) I am telling my family and friends not to buy one like this. I've gotton no help from calling Sears or Kenmore.
  • Anonymous Mar 13, 2009
    Er FF is displayed on the screen over the ice and water dispenser.
  • Anonymous Mar 16, 2014
    My elite refrigerator model 72053 has error code cf
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Mar 19, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
2079
Points
ER FF - found in another post = Error Freezer Fan. Removed freezer back panel (inside freezer), defrosted ice build up around fan. Error message gone for now. Easy fix at midnight - 20 minutes. Will be looking into ice-up cause.
  • Anonymous Jun 10, 2012
    Thank you ~ your solution fixed the problem! Now I was glad that my husband was home and he could remove the back panel and remove the ice build up. It wasn't all that mechanically challenging...he just had to remove a few screws, unplug the ice-maker and finagle the back panel off...HOWEVER...should this problem ever arise again an, or you do not feel up to all that work just to get the fan going , I would try just unplugging it, emptying the freezer contents into a cooler, chip away at any ice build up up you can see and leaving the door open and let it defrost naturally.Takes more time, but it is a lot less work!
winserp
Level 3:
Master:
  • Master 363 Answers
  • Posted on Dec 28, 2016
winserp
Master
Level 3:
Master:
Answers
363
Questions
0
Helped
211020
Points
1105
Hello, everyone, have you ever played a game called RuneScape? I heard this game is very popular before, and now there are still many players, and recently I found a website may be able to help you, to share with you www.rsgoldfast.com
3 Related Answers
Anonymous
  • 15935 Answers
  • Posted on Sep 25, 2010
SOURCE: er-ff error message on Kenmore Trio 795
This is an error code that pertains to the evaporator motor but could also be the main board.
If the evaporator motor is running, the main board will probably need to be replaced.
It could be a wiring problem but it's not very likely.
If the motor is not running, some voltage checks will need to be made, at the motor and board, to determine which component has failed.
These checks require a meter and can be difficult to make, even for a technician.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Anonymous
  • 8619 Answers
  • Posted on Jun 30, 2010
SOURCE: what does ER FF mean on my Kenmore Elite bottom
Hi
Thanks for using FixYa. Error ff is freezer fan fault. This usually happens when either the rear board has gone bad or the freezer fan itself is bad and needs to be replaced. To check what is causing the error you can start with checking the fan which is located behind the back wall inside the freezer. Also check the rear board as it might not be putting the fridge into defrost long enough and is causing the ice to build up in the freezer and thus stopping the freezer fan from turning and so causing ff error. Leave the fridge unplugged for 24hrs which will melt all the ice then plug it back if still the issue is not resolved and you hear the fan running then it is the rear board that needs to be replaced. Please do rate the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Anonymous
  • Posted on Dec 22, 2009
SOURCE: I have a Kenmore Elite Trio Refrigerator. The
I have the same problem what is the solution
Top Kenmore Refrigerators Experts
vince
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
