SOURCE: universal RCA remote control
Your going to have to read the directions or owners manual and do a scan search. Its very easy. READ READ READ
SOURCE: timer record set
Make sure the clock is set. Since the clock must be set before the timer will work, be sure you have entered an accurate date, day of the week, and time (including AM or PM). And always check the clock after a power outage. Also, check that your videotape does not have the tab removed which protects against further recording.
SOURCE: Remote control programming
Found this site. Still had issues with the remote. Uggghhhhh....
http://www.homecable.com/zenithremotemanual.pdf
SOURCE: Zenith TV not programmed for home purpose
Got the same problem. How can we reprogram these TVs?
SOURCE: programming
push the tv button then hold down the code search button till the light becomes solid. point the remote at your tv while it is turned on and push the channel up or down til the cannel changes. once it does push the mute key to save. so u know this works like that on all device and if you pass up the right on from pushing the button too fast you can just push the opposit direction rather than waiting for full circle. also be aware that there are multiple codes for some devices and some work better than others.
