Frigidaire FEB24S2AS / FEB24S2AB Electric Single Oven Logo
A
Anonymous Posted on Dec 12, 2010
What dose f1 mean - Frigidaire FEB24S2AS / FEB24S2AB Electric Single Oven
espressonist
Level 3:
  • Frigidaire Master 1,711 Answers
  • Posted on Jan 01, 2011
espressonist
Frigidaire Master
Level 3:
Answers
1711
Questions
Helped
661932
Points
5029
F1 touch pad / ERC test This simple test will help determine
whether the ERC (Electronic Range Control or Clock) or the touch pad is
defective when F1 error code is present.
Note: Some models incorporate the touch pad in to the ERC as a single
assembly, in which case this test is not necessary. Simply replace the ERC
(Clock).
Warning: If you feel in any way uncomfortable performing this test or
making this repair, please contact a qualified appliance repair technician.
1. Disconnect power to the range (unplug the range power cord or turn the power off to the range at the circuit breaker). It is very important that the power to the range has been disconnected, so please double check before continuing
2. Gain access inside the control panel.
3. Disconnect the touch pad (also called keypad or membrane switch) ribbon from the ERC
4. Make sure there are no lose wires, or anything else that may cause a short when power is turned back on. Assemble the control panel back the way it was
5. Turn the power back on.
6. Wait for at least one hour to see if the F1 code comes back (usually accompanied by a beeping sound)
7. If F1 comes back, replace the ERC. If it does not, replace the touch pad.
What does F1 mean on Gibson gas self cleaning oven
The code F1 Gibson gas self-cleaning oven means
Oven Control Failure. You need to go through the manual
And check for possible solutions if you are getting an f1 error.
Dec 01, 2020 • Ovens
tip
What the F1 code means on your OVEN
The F1 error code means that the computer thinks a button on the touchpad is stuck. Sometimes this can be resolved by making sure the touchpad connector fits tight into the control board. The F1 code can be cleared by pushing CANCEL/OFF. If it returns the touchpad needs to be replaced .
on Aug 05, 2011 • Ovens
1helpful
What does E2 -F 1- mean?
A E1-F1 or E1-F2 is a faulty touchpad.
FixYourBoard.com has replacements about for NLA ovens.
They come with a two year warranty.
Reach out to us at 512-355-1108 or info@fixyourboard.com
F1 code after installing oven, cut power to unit for 30 min. then F7 code displayed. What do they mean? This is a model SC302ZS Thank you for your help.
F1 means internal logic failure; control needs to be replaced
F7 means function key shorted (touch pad).
Hope that helps.
The digital program shows F1. What does this mean?
F1 means there is a problem with electronic oven controller.
The solution is to replace it.
1helpful
What does the F1 mean
Hi, the F1 error code means a problem with the System Watchdog Circuit..
Press "Cancel", if beeping continues after 30 seconds, replace the main control board (also called clock or ERC).
The oven beeps and has a error F1
Hello,F1 means Stuck touch pad.
Usually means that either the touch pad or the oven control (also called clock or ERC) is defective and needs to be replaced. If this fault code cannot be canceled,replace the oven control(also called clock or ERC),touch pad,or both.
Thanks
F1 flashing on gas stove-manual says to push clear-where is clear button
HI. This actual code cannot be cleared by pushing the Clear/off button. This actual button will usually be located on the touch pad and is a basic cancel button. You can try to reset the entire control board by simply unplugging the unit for 5 minutes. This may correct the issue. If resetting dose not correct this fault, the necessary actions are to have the defective main PCB replaced, asap.
F1 - Defective control board(PCB)
Model 79092423302 flashing F1 what dose this mean
Here is some wisdom for understanding F1 fault codes.
In some models, there are subcodes that make diagnosis even easier.
Here's a simple explanation of what's going on and how to troubleshoot:
The F1 code indicates that:
a. The electronic range control (ERC) is sensing heat in the oven when in a time-of-day (i.e., not cooking) mode.
b. The ERC is receiving information to run multiple heat functions simultaneously.
Although different components (depending upon the model) could generate the code, simple and straightforward testing using your ohm meter is all you gotta do to test for it.
1. Check the oven temperature sensor. The oven sensor has to be within spec or it will cause the F1 code.
As an example of being out-of-spec, the ERC will generate an F1 fault code when the sensor shows 1650 ohms during a time-of-day mode.
This is equivalent to 350°F in the oven.
The resistance isn't high enough to generate an F2 code (runaway temp) or an F3 or F4 code (shorted/open sensor circuit).
The ERC monitors the sensor circuit after a heat cycle and expects the resistance to drop back to 1050-1100 ohms.
The fault code is generated when this doesn't happen. Checking the sensor circuit means also checking the harness,
harness connections and the sensor itself.
2. If the oven sensor circuit checks okay, then turn your inquisitive eyeballs to the touchpad.
If the range has a separate touchpad/keyboard, the keypad may have moisture that is shorting several circuits simultaneously.
If the F1 code is given immediately (instead of during or after a heat cycle),
remove the ribbon connector from the touchpad to the ERC after clearing the F1 code. If the F1 code does not return in five minutes,
then cast a suspicious gaze upon the touchpad/keyboard. Shorts may be caused by using an ammonia-based glass cleaner.
The touchpad surface will absorb ammonia-based cleaners that are sprayed directly on the glass surface. When heat is applied,
the surface material can break down causing shorts.
If you're gonna use ammonia-based cleaners on your control panel, then you should spray it on the rag and then wipe the touchpanel
-don't spray directly onto the surface of the touchpad.
3. On Amana ranges with a rotary temperature dial, be sure that the knob is in the OFF position when performing tests.
4. If these tests all check good, then replace the ERC.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
!@$#w
Top Frigidaire Ovens Experts
Paul Carew
john h
vince
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
