SOURCE: belling oven stopped working
It is most likely the element needs replacing although it could be the oven thermostat.
I would try a new element first, it is not a complicated job to change the element but you need to switch the power off at the wall before you start work.
If you are unsure or in doubt about carrying out the work seek professional help.
Testimonial: "thanks ashburton i will attempt to change the element first."
SOURCE: Oven no gas
pilote tube could be blocked or pilot orifice set too small. check that the gas pressure is ok
SOURCE: Hi, I have a Belling
I'm not a cooker expert, but try the following. Get a bit of electrical flex, strip the covering and part it so you have one fine strand. Poke this into the tiny hole in the centre of the jet underneath the ring and jiggle it about. The jets often get blocked by grease or a bit of dirt in the pipe same as the washers on a car. Costs nothing to try.
SOURCE: Chef premier 091S16FE1 gas cooker.
I dont have a diagram but most Chefs have a wiring diagram stuck behind the lower kickpanel or underneath the warming drawer ( if fitted) The Premier was a fairly basic unti when it came out. A lot of these had battery ignition. Look behind the kickpanel or under the warming drawer for a battery box. ( About the size of a matchbox) and has a 9volt radio battery.
I have not seen fuses in these ovens for over 10 years , so I would suggest that yours doesnt have one.
