Computers & Internet Logo
Posted on Dec 10, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Compatable ram - Computers & Internet
Anonymous
Level 2:
Scholar:
  • Expert 85 Answers
  • Posted on Dec 10, 2010
Anonymous
Expert
Level 2:
Scholar:
Answers
85
Questions
0
Helped
23857
Points
243
Yeah, RAM is compatible with desktop PCs. Which RAM is compatible depends on your motherboard.
Very very slow need ram upgrade just want to find out how much ram i can put in to it
When purchasing RAM make sure ram modules are of the same brand any type
IE corsair ddr3 low density or hynix high density ddr2 you should always try to keep the same brand and type of ram
reason being the compatibility issue
and always place the largest ram module closest the CPU central processing unit
also check the ram sockets for dust and make sure the ram modules are securely seated you can do this by pressing the levers at either end of the ram sockets.
If you're not sure if a module is right for your system, use the
Crucial Memory Advisor tool for a list of guaranteed compatible modules.
First you will need to select the manufacturer from a drop down list then select your product line from a drop down list then select the model then click find it will take you directly to compatible ram also you will have an option to scan your system.
You should always ask for a guarantee on the compatibility before making any purchase and try to buy for working pairs if possible.
1helpful
Added 2*1GB Offtek RAM (DDR2-6400 - Non-ECC) to Dell Inspiron 530 alongside original 2*512MB Samsung memory. Get two beeps at startup (No memory modules are detected). Starts fine with original memory but...
It may be compatible, but is it also rated as compatible by the Dell website? and is it the same type of RAM as your old RAM? According to the Dell website your system comes with 2GB as standard and will only accept 4GB maximum. The fact that the system doesn't start with only the new RAM and is fine on just the old RAM would indicate that your new RAM is not compatible or is faulty.
1helpful
WINFAST N15235 MANUAL
Hope this helps.
Ram compatibilty
Yes you can but the higher spec DDR2/800 RAM will run at at lower speed same as the DDR2/ 667 RAM.
When you install the DDR2/800 RAM and the BIOS only detects 1Gb of RAM then this RAM is not compatible with the 1st RAM module. In this case use RAM module that is the same make and speed as the original RAM module.
Does not take my pc3200 RAm
The PC3200 memory that you are trying to install may not meet the specific compatibility needs of that particular motherboard. Below is a link with a compatibility guide so that you can see if your particular memory is compatible. If you find that you meet the requirements on the chart, it could simply be that there is some dust lodged in your RAM slots causing the chip to not make a full connection. If you are still having problems and you are certain that your RAM is compatible, it is likely that the RAM could be faulty. If you have recently purchased this RAM, simply bring it back for an exchange.
RAM compatibility HELP
Yes this pc3200 is hardly compatible, because your motherboard is supportable of DDR 1 type RAM, Hence th PC3200 = 400 MHz, so you can add this ram to your PC, such that the ram which is between 266mhz to 400 MHz is absolutely a DDR1 type . please dont forget to vote for me.
3answers
Cant install new 1gb pc3200 memory into my chaintech apogee 9pjl motherboard. as soon as power is turned on, i either get a constant beep or a neverending intermitant one. please help.
Some memory brands are not compatible with some motherboards. Go to the motherboard web page and check it for the kind and brand of memory you can use.
1helpful
Ram Upgrade
Yes, you can increase the RAM of your Asus X53L, but first, please review/check the product manual of your laptop on what type & maximum capacity of RAM will its motherboard can support & compatible. Any Brand of RAM will do as long as your laptop motherboard is compatible wih & can support its capacity, this is being made to ensure best operations performance of PC. regards
Does my computer compatible to upgrade RAM?
Yes. It should easily adapt a 1GB Ram. The 32bit processors can genarally take upto 3GB of RAM
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
