ValuSoft Let's Ride: Corral Club for Windows Logo
Posted on Aug 07, 2017
I have used my Let's Ride Corral Club for Windows game for years, and have had it on every computer I owned. I recently purchased a new laptop with Windows 7 and it will not install in my computer. It begins the installation process and says "preparing to install" and then just stops and reverts back to my desktop. I have installed other Valusoft games on this computer and they work fine.
3 Related Answers
jwalant
  • 17 Answers
  • Posted on Nov 11, 2008
SOURCE: Let's Ride Corral Club will not run
To make the all the files of the game compatible to Windows Vista you need to install the game and then make changes to the game exe file.
Some game ".exe" file (executeable file) would let you make changes in the Compatibility option, whereas older games might not give that option at all.
You can still try to make the game compatible for installing it on the Windows Vista by following the steps below.
1. Insert the game disc in your CD-ROM drive, if the game setup or the autorun starts, exit it.
2. Open "Computer", Right Click the Cd Drive which has the game disk in it and select "Copy".
3. Go to your "Desktop" right click and then select "New" and click on "Folder" this should create a new folder on your desktop.
4. Open the New Folder and then Right Click and select "Paste".
6. After all the files are copied to the "New Folder" without any error messages then locate the file "Setup.exe" or "Setup" and right click and click on "Properties".
7. In the new window click on the "Compatibility" tab and run the program in compatibility mode for "Windows XP Service Pack 2" and then click on "Apply".
8. After applying changes double click on "Setup.exe" or "Setup" to launch the installation.
9. After the game is installed go to the game directory and find the "LetsRide.exe" and click on "Properties" and repeat step no.7
You can delete all the files copied from the CD after completing the installation
The game files need to be copied to the hard drive because the files on the game disk would not let you make changes while on the disk.
There are lot of files that need to be changed in order to get full functionality and to communicate with operating system and the hardware, hence there is no guarantee that the game might run even in cases where you will successfully install an older version of the game with the above mentioned steps.
The same set of steps can be used for installation of older games installation on Windows Vista.
Anonymous
  • 1555 Answers
  • Posted on Jun 27, 2009
SOURCE: i have downloaded let's ride corral club but when
Kindly let me know what OS you are using and kindly go through the readme file of your game wether it supports your OS or is it made exclusively for few OS. or just paste a link from where u downloaded the game.
Anonymous
  • 100 Answers
  • Posted on Jul 02, 2009
SOURCE: i still didn't get it there is no readme in let's
do not know have not got the game
Top ValuSoft Video Game Consoles & Games Experts
john h
James Wishart
Anonymous
Level 1 Expert
Are you a ValuSoft Video Game Console and Game Expert? Answer questions, earn points and help others
