Norelco Cool Skin Moisturizing Electric Shaver Logo
Posted on Dec 03, 2010
How do you replace the battery for a norelco cool skin 8020X razor?
5 Related Answers
A
Anonymous
  • Posted on Nov 25, 2007
SOURCE: it will charge up any more? where can i get new battery?
smallappliance.com
Robert McClure
  • 162 Answers
  • Posted on Aug 23, 2008
SOURCE: how to change battery in Norelco 5841XL razor
it's soldered in
brector3
shaveroutlet.com
  • 1652 Answers
  • Posted on Jan 24, 2010
SOURCE: battery is not holding charge as long as it used
Sure, the batteries can be replaced. Some soldering is required. If you are capable, you can do it yourself or you can have it professionally done. shaveroutlet.com offers the batteries or repair service. See links below
http://shaveroutlet.com/shaver-battery-pack-for-most-norelco-more-p-278.html
http://shaveroutlet.com/professional-battery-replacement-for-most-models-p-374.html
If you decide to have it professionally done, you can simply purchase the repair service from the website and follow the instructions for sending it in to the company.
If you do it yourself, you will need toremove the two screws on the back of the shaver to remove the back cover. You will the see the batteries andwhere they are connected to the circuit board.
You may find it easy to use a modified installation technique. This is to break the tabs off of the old batteries rather that removing them from the circuit board. You can use a small flat screwdriver or similar object to do this. This allows the old batteries to be removed but leaves their tabs attached to the circuit board. You can then solder the tabs from the new batteries to the old existing tabs
brector3
shaveroutlet.com
  • 1652 Answers
  • Posted on Apr 16, 2010
SOURCE: Norelco 985rx Overheats upon charging..
You should always use the same type batteries that your shaver was designed to be used with. Your shaver was designed for use with NiCd batteries. If you have use NiMH batteries this may be causing the problem you described.
However, I would say that it is more likely that you have some sloppy solder that is bridging something that is not supposed to touch. You should check the battery solder joints on the circuit board and clean up any sloppy solder work that may be there.
brector3
shaveroutlet.com
  • 1652 Answers
  • Posted on Aug 10, 2010
SOURCE: I have a norelco cool
You will find a battery pack for model 6711 at shaveroutlet.com. See link below
To open the shaver, you will need to remove the lotion packet cover on the back revealing 4 screws. There may be a screw near the bottom also. Remove screws to take off the back of the shaver and access the insides.
For easier replacement, it is sometimes suggested that you use a modified installation technique. This is to break the tabs off of the old batteries rather than unsoldering them from the circuit board. This allows the old batteries to be removed but leaves the tabs attached to the circuit board. You can then solder the tabs from the new batteries to the old existing tabs
Top Norelco Health & Beauty Experts
ADMIN Andrew
ADMIN Andrew
Ngoro
Are you a Norelco Health and Beauty Expert? Answer questions, earn points and help others
