Pentax ME Super 35mm SLR Camera Logo
Posted on Dec 03, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How can you rewind the film - Pentax ME Super 35mm SLR Camera
Level 3:
One Above All:
The expert with highest point at the last day of the past 12 weeks.
Top Expert:
  • Pentax Master 102,366 Answers
  • Posted on Dec 03, 2010
Pentax Master
Level 3:
One Above All:
Top Expert:
Answers
102366
Questions
0
Helped
10724326
Points
622696
Lift up the rewind crank. Press the film rewind button on the bottom of the camera and turn the crank clockwise. Rewind until the tension on the crank lessens, indicating that the film leader has been released from the take-up spool. Pull up on the film rewind crank and the back will open.
1helpful
Film rewinds when loaded
Align film leader at mark, then close the camera back for prewind loading. Film rewinds as each shot is exposed. Built-in motor for automatic winding/rewinding. Film advance: Automatic. Single-frame and continuous (1 fps). Automatically rewinds film leader into cartridge when designated number of frames have been exposed (midroll rewind available).
sorce: http://www.canon.com/camera-museum/camera/film/data/1996-2000/1999_eos3000.html?p=2
Canon Camera Museum Camera Hall Film Cameras
good luck
3helpful
Is there a manual rewind on nikon n65?
If by manual you mean turning a crank to rewind the film, no. If you mean to do it at a point other than the end of the roll, yes.
To rewind film mid-roll, press the two film rewind buttons simultaneously for approximately one second. The film will then rewind and the frame counter will count backward. The film is completely rewound when the E appears in place of the frame number.
The two film rewind buttons are marked with a red film canister symbol with left-pointing arrows. One is the exposure compensation button next to the control panel, the other is the self-timer button next to the mode dial.
If you need a manual, you can download one from
http://butkus.org/chinon/nikon/nikon_n65/nikon_n65.htm
1helpful
My Canon AE-1 Program will not rewind. I shot the whole roll, rewound a little, and then accidentally opened the back cover. The counter reset to S, and the rewind crank just unscrews when I try to...
I think you have already ruined the film except the frames that are rewind back to the film cartridge.
You can take the film out from the camera, push in the rewind button at the bottom, pull out the film from the film take up reel.
On the film cartridge, turn on the long tube in the middle clockwise to wind all the film back into the cartridge.
If you had the back opened briefly, do manual film rewinding in the dark room.
3helpful
How do i rewind the film in my nikon n2020
Set the film advance mode selector to L.
While sliding film rewind lever, push film rewind button.
Fold out film rewind crank and rotate until film advance indicator stops moving.
If you don't have a manual, you can download one from http://www.butkus.org/chinon/nikon.htm
8helpful
How do you change the film in a minolta x-370n?
push in the rewind button on the bottom of the camera. turn the rewind knob to the right until all the film is rewound into the film canister.
pull up on the rewind knob to open the back ( film ) door, remove canister. put new film into camera push rewind knob down and pull enough film to attach to the take up spool.
5helpful
FILM WILL NOT REWIND
On the N80 - there are custom functions you can set in terms of when a film rewinds. Normally it is default to rewinding automatically at the end of a film. If this setting has been changed, or you want to rewind a film before the end - you need to press two buttons and hold them, at the same time.
The first button is the LCD backlight button next to the LCD, and the second is the flash sync button on the rear of the camera. Both should have a little red film symbol on them. Press them both and hold them, and the film should begin to rewind.
Can't rewind film
It should automatically rewind when the roll is at the end. For mid-roll rewind press both the rewind buttons simultaneously for about 1 sec and the film will rewind.
Film rolls back automaticaly
The camera shouldn't be doing this, assuming you're using 36 exposure (or 24 exposure) film. You may want to set a custom function to prevent automatic rewind -- you would have to rewind the film yourself by pressing the rewind button.
To do this:
1. Under the palm grip, press the 'CF' (custom function) button.
2. Use the main dial to select 'F1' in the LCD. It should show a '0' below the 'F1'.
3. Press the 'CF' button to change the '0' to a '1'.
4. Press the shutter button half way to save the change and exit the custom function setting mode.
If you want to stop the rewind with the film leader still exposed (film doesn't rewind entirely into the cannister), use the same steps but set custom function 'F2' to a value of '1'.
Film Rewind
check the mechanism inside the film compartment, it may have a broken rewinding gear, if there's nothing broken clean the contact point inside the film compartment, use cotton buds and alcohol or fluid.
Top Pentax Photography Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Pentax Photography Expert? Answer questions, earn points and help others
