Which Utilitec timer do you have?
Following page has instructions for 0192773, with links to 0155671, 0144506, and 014124 programmable timers:
http://waterheatertimer.org/Program-wire-Utilitec-0192773.html
Add a comment with your timer ID and I will help more.
If your timer is not shown on link above, add a comment and describe your timer.
I have extensive files on timers.
I have a utilitec 015567 timer that I set for a MTW 10pm to 6 am on off cycle.
This worked fine.
However, the timer also turned for the rest of the week. Looking at the other days I cannot see where anything is programmed to come on during the remainder of the week.
Suggestions?
thanks!
I do not have repair for defective timer.
This is popular timer sold under 6-7 different brand names and numbers, and hardly ever see a complaint or problem.
Try resetting timer, and then reprogram.
Check there are no conflicts in programming that cause timer not to operate as expected.
Use timer on different outlet with different load.
Check outlet with circuit analyzer. If outlet polarity is reversed, then timers might go bad frequently.
If timer is defective, buy another one at Target or Lowes, and then return defect in new package.
Thanks!
