SOURCE: Need a code for my Comcast Universal Remote
30176 is the code you need . Press Aux and then hold setup until Aux lights up. Enter code. If you want the remote to control the receiver all the time, press Aux and then hold setup until Aux lights up. Enter 993 then press Aux. Aux will flash, now press Cbl and Aux should light up when you use the volume.
SOURCE: What remote control code does the Onkyo TX-SR304 use?
From: http://www.comcast.com/remotes/universal.html - only worked for me when I had AUX setup with 30135
Unlocking Volume Control For A Single Device (Individual Volume Unlock):
Now, after you select a device that has volume unlocked (e.g., AUX), pressing VOL , VOL-, or MUTE will control the device's volume only in its own mode.
If desired, repeat steps I to 3 (of this section) for each device that you want volume to be unlocked.
SOURCE: looking for remote code for sherwood rx4105 to work with comcast
Ask the remote code experts -
They will get it for you.
http://manualfox.com
