Frigidaire GLTF2940ES Front Load Washer Logo
Posted on Jun 26, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
E20 ERROR CODE - Frigidaire GLTF2940ES Front Load Washer
  • 8 more comments
  • Anonymous Jul 10, 2008
    E20 err code comes on in middle of cycle and cycle will not finish. I have tried restarting the cycle and it gets partly done and will not finish. If it does comlete the clothes are not spun out comletely and remain too wet to put in dryer.
  • tairilynn Sep 08, 2008
    Same thing happens to mine!!! HELP!!!
  • Anonymous Sep 13, 2008
        The E20 code comes on in the middle of a cycle and then it it will not drain completely or spin close out.
  • mmkwelch Sep 14, 2008
    Please help with E20 error.
  • boomerang769 Dec 03, 2008
    error 20
  • billdugas Dec 05, 2008
    What does it mean?
  • Anonymous Dec 14, 2008
    Does anyone have a diagnostic code chart for this?
  • Anonymous Dec 19, 2008
    e 20 code
  • tonyanjanes1 Jan 03, 2009
    where the fliter at
  • Anonymous Feb 04, 2009
    i keep getting E20 error code
Anonymous
Level 3:
President:
  • Master 1,294 Answers
  • Posted on Mar 17, 2009
Anonymous
Master
Level 3:
President:
Answers
1294
Questions
Helped
911668
Points
3466
Plug off the mains. First drain out all your water by lowering the exit hose into a bucket or drain. You have to look for screws below the front kick-panel, the panel comes down & out. The pump is on the right side. Be prepared for dirty water. Inside the big flexible tube (coming from the tub bottom) is the filter, be prepared to find all sorts of junk here, clean out. Examine your pump also, clean out the impeller. Carefully refit all. Your machine would be fine. Don’t wait for the machine to jam to look into your filter.
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Sep 18, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
1759
Points
6
My front load washer has an E20 error code that will not allow my washing machine to finish the spin cycle. How do I fix this error?
Anonymous
Level 1:
  • Posted on Dec 31, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
1759
Points
It means that machine isn't able to drain. Either check the filter, make sure the house drain isn't clogged, or if the hose is kinked.
Anonymous
Level 1:
  • Posted on Dec 07, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
1759
Points
My frontlad gives e20 code
E20 Error
Hello Diane Snow, thank you for your inquiry!
I understand that your Frigidaire washer is displaying "E20" error code. The "E20" error code means water is not pumping out fast enough. First, you want to check the hoses for restrictions.
If the hoses are not restricted it could be an issue with the drain pump or control board. I would suggest seeking assistance from a professional technician for proper repair. I hope this is helpful. -Matt
Gltf2940es3
good day,
no idea for the E20 error coz all brand have diff error code?
call the service center what the exactly the E20 error?
check in the manual for the error code most of washing machine if the error code is in users manual its means its only minor problem,but if the error code is not in users manual its means you need to call an service technician to not waste your money or time if you do by your self.
Frigidaire front load washer (ATF6000SF1) error E20
E20 is not an exact error code. It's indicating a possible pump out problem. Here is a few possible causes of an E20 error code:
1. Restriction in the drain pump
2. Failed pump
3. Water not pumping out fast enough (crimped drain hose)
4. Too many suds ( too much detergent or wrong kind)
5. Pressure switch (not communicating with control board)
6. Loose wire at pressure switch
7. Loose wire at pump or control board
8. Failed control board
I have a Kenmore Elite washer, model 44092. The machine won't spin and the error code is E20. What is wrong with it?
The machine, based on the error code, is made by Frigidaire for Kenmore. Error code E20 pertains to a slow or no drain problem which can be due to a clogged/kinked drain hose, blocked drain filter/coin trap, or a broken drain pump. The link below provides the detailed troubleshooting procedure of this error code.
Error Code E20 on Frigidaire and Frigidaire-made (including Kenmore) Front Load Washing Machines
6helpful
E20 message want spin
2. Failed pump
E20 code. Not draining
E20 is a general error code to get to the real problem try this..
Reading Error Codes 1. Wake the washer by pressing any button. 2. Wait 5 seconds. 3. Press and hold the START/PAUSE and CANCEL buttons simultaneously. As long as the buttons are held, the failure code will appear in the display as an “E” followed by two numbers, a number and a letter or two letters. The control will beep and the Door Lock, Wash, Rinse, and Final Spin indicator lights will flash. let me know what code come up... hope it helps
1helpful
I have a 97 Buick Regal and I get a E20 error message:cd player
If the CD is over 60 minutes it will not play on domestic cars
11helpful
AEG Lavamat Turbo 12830 - error code E20
Hi
E20 means there is a bolckage in there
remove filter and clear any debris in there and check impeller is turning ok.
regards
18helpful
4answers
Zanussi Electrolux ZWF 1430 W (E20 error)
Check water "forreign object trap". It's under the lid at the bottom of the machine. First drain water by pulling out the hose and pull out the plug. Then unscrew the trap. Have had this E20 error twice. First it was two coins there, next it was a big paperclip. Have worked fine ever since.11_20_2011_8_57_27_am.jpg
Top Frigidaire Washing Machines Experts
Sudeep Chatterjee
Sudeep Chatterjee
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
