SOURCE: need code for direct tv for my rca remot universal control rcu600d
The product you are trying to access may be called DirecTV(different spelling). You will need to find the make of your set top box used to decode the DirecTV and then look up satelite codes in the user manual for the remote to select the correct code.
the manual for the remote can be found at
http://www.remotecentral.com/cgi-bin/files/rcfiles.cgi?area=other&db=devices&br=philipsmagnavox&dv=universalremote&md=pm435&kw=pm435s&st=&ar=&dt=&so=&pg=1&file=others/philips/pm435-manual.zip
In case you dont have the book still. Good luck.
Any drama, get back to me here.
regards
Graeme
SOURCE: US2-PM435S PHILIPS UNIVERSAL REMOTE, I
heres a link to the phillips universal remote site it has all the codes and programing instructions that you require.
SOURCE: I need a code #
I own a One-for-All universal remote, and my booklet says the setup code for a Prima TV ( without a built-in DVD or VCR) is one of the following numbers: 0761, 0783, 0815, 0817. I can not guarantee these numbers will work with your remote, but it is worth a try.
I assume your DVD has been attached separately, and not built into the TV. In some cases, you might not need an additional setup code. Once the TV has been turned on, you simply push the DVD button on your remote, to activate the DVD. The instructions which came with your remote and your DVD should provide you with more details. If the instructions indicate that an additional DVD setup code is required, then please respond by telling me the brand name of your DVD.
SOURCE: programming rca universal remote for my toshiba tv
I can't exactly help you, but can you tell me how you programmed the remote to your TV, because I cannot get mine to work...
