Fisher Price Fisher-Price L8341 Digital Camera Logo
Posted on Nov 28, 2010
Have error code #53... - Fisher Price Fisher-Price L8341 Digital Camera
What is error code 53? Treadmill only working when incline is 0.5. When change up or down, it shuts down.
Error code 53 typically indicates a problem with the incline motor or the incline sensor on a treadmill. It could be caused by a malfunctioning incline motor or a problem with the wiring or connections between the motor and the sensor. The fact that the treadmill only works when the incline is set to 0.5 suggests that there is an issue with the incline mechanism and it may need to be serviced or repaired by a professional.
HELP! I have a Daewoo Lanos(1998-99), ive got a
The fault code 53 is an ECM IMMOBILIZED ERROR.
The immobilizer anti-theft system thinks the key is invalid. If it detects an error, it will;
Disable the fuel injector circuit--- Disable the fuel pump circuit---Disable the ignition coil.
Code 53 will set when:
1- The Eectronic Control Module (ECM) does not receive the signal from the Immobilizer Control Unit (ICU) within 0.9 seconds when vehicle is stationary, or 1.8 seconds when vehicle is moving.
2- The ICU sends the ECM an incorrect release message more than 5 times.
3- The above conditions continue until the ignition is switched off.
I hope this helps.
8helpful
Scania 114G 340 is not running after EDC warnings, error codes 53 and 54 can some one help me out.
the fault codes 53-54 is problem in cylender 3and4 unit injectores but that is not the main cause to make the engine is not starting check the overflow valve and the fuel pump or another fault code in the control unit
Need error code information for 1995 Ford Aerostar minivan
Code#53: throttle position sensor high voltage. #85: canister purge failure. 36: (CSI) flow low or low revolutions per minute increase.
Heater diagnostic codes (2000 jeep grand Cherokee)
49- dimming input is in error
53-door range travel was to small
56-door range travel was too large
I am not sure what they mean. I just happen to have the book of codes
Code 53
Hello yeremya1776,
For Jeep Grand Cherokee, 1991-95 models:
Code 53 - Internal Controller Failure - Internal engine controller fault condition detected during self test
Hope this helps.
Remember: Good things come to those who Rate!!
Mike
Hp 4si
Your post is correct that error 53 refers to bad memory board or at times defective SIMM only. Since you have replaced them and no change, you may want to try to do a Cold Reset of the printer. This is done by powering on the printer while holding down the GO or Online button. Additionally, you may want to check/reset your NVRAM settings which can be done manually through the Service Mode.
This page lists most of the HP Laser Printer error codes. This link displays most HP LaserJets - Cold Reset Instructions.
Hope this be of some help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Top Fisher Price Cameras Experts
Tony Parsons
Tony Parsons
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Fisher Price Camera Expert? Answer questions, earn points and help others
