SOURCE: Fixing unit error. Turn off and
The problem is in your fixing unit
the reasons may be
(i)The thermistor has an open circuit or a short circuit.
(ii) he heater has an open circuit.The thermal fuse has blown.
(iii)The power supply PCB has a fault.
(iv)The engine controller PCB has a fault.
Check the following,
- Check the connector of the fixing film unit.If found no problems,
-Replace the fixing film unit.Not solved?
- Replace the power supply PCB.Still having problem?
- Replace the engine controller PCB.
and that's it
SOURCE: when print command given to
good day sir.this a fuser temp error. These units are notorious for having fuser temp errors when there is dirty or unstable power, especially if the customer is running off a generator. the best way to fix this is to replace or rebuild the fuser assembly. goodluck!
