D-Link DES 1005D (DES-1005D) 5x10/100 Mbps Networking Switch Logo
Posted on Jun 16, 2017
I have a weird problem with my switch . It doesn't give me internet acces when i try to connect my pc with it but when i connect a router to the switch it does work . I tried everything : restarting my switch , changing network cards , even restarting my modem didn't work . Could this be a problem with my switch ? Modem => main switch (for tv , and 1 router for other wireless pc's) => My switch=> my router => acces point(ipod)
Level 1:
Problem Solver:
  • Contributor 18 Answers
  • Posted on Jun 29, 2017
Contributor
Level 1:
Problem Solver:
Answers
18
Questions
0
Helped
1713
Points
28
Do your service provider limits number of ip address (10.10.10.10) you can have? if they provide only one, you would need to use a router to share one public ip address. Sometimes it records the network address of your network device (00:00:00:00), and won't give u another ip if the device changed. If you have two routers in your network, turn off the dhcp on the second router, and use LAN ports and do not use the WLAN on the second router. if you want to manage the second router, give it an static ip from the first router. Bad port? Bad cable? Modem => router => PC/IPOD/switch or modem => router => PC/IPOD/Switch/ 2nd Router without dhcp and no WLAN ) Good luck
5 Related Answers
Anonymous
  • Posted on Feb 27, 2009
SOURCE: D-Link Wireless Router WBR-1310, Version A1
I had the same problem.
Make sure you turn off all the security with the software in package then slowly turn it all back on, on piece at a time. For whatever reason, it comes with MAC address filtering already turned on, which makes it impossible to see if you don't have the right info put in to the computer that the router was configured with.
Anonymous
  • 68 Answers
  • Posted on Mar 22, 2009
SOURCE: Dlink WBR 1310 not connecting to a MAC(Apple) network
With power on, push & HOLD reset button on rear of router for at least 10 secs - then release. UNplug power to the cable modem while you're doing all this. Then, plug power to modem back in, and try router connect to computer again.
Please let me know - and if you wouldn't mind, please take the time to rate my response to you.
Thank you and good luck.
gurutim
Anonymous
  • 611 Answers
  • Posted on Apr 04, 2009
SOURCE: how to connect ADSL 2 modem to Wireless Router
just change the ip address in the router and give the proper settings in the router
kakee
Michael Galve
  • 1269 Answers
  • Posted on May 11, 2009
SOURCE: I hooked up a D-link DIR 615 wireless router, and
What is the brand of your modem? Are you on DSL or Cable internet?
Anonymous
  • 700 Answers
  • Posted on May 18, 2009
SOURCE: Not able to configure and connect to internet using router
Manually configure the setting in your LAN, this could help.
Connect a LAN cable between LAN1 of your router then to the LAN port of your computer. Power the router.
Goto Lan settings, highlight TCP/IP, then click properties.
In your lan settings manually input IP address 192.168.0.52, Subnet 255.255.255.0, gateway 192.168.0.1
You can input also the DNS number of your IP.
Then open web browser type in the address bar 192.168.0.1. You should go straight thru router utility setup security log in.
This can also be set wirelessly. Leave comments if I miss something.
Top D-Link Computers & Internet Experts
Narseman
Grand Canyon Tech
Grand Canyon Tech
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
