Kit comes with minimal instructions. you need to remove the burner which requires removal of the top panel, control panel and front panel. (see how do I remove front panel on samsung dryer for more details). It is fairly easy, maybe an hour the first time you have done it. Pay attention to all of the instructions re the burner, do not losen any of the gas tight fittings!
What is a LP conversion kit?
SOURCE: how do i get to gas valve to install lp gas
call your lp provider as they often will send out a tech to do this conversion for free. after all you will be buying the gas from them.
SOURCE: Bought Kenmore 796.9044 gas dryer
It should come with a manual. It does simply installs after removing the other regulator & do use pipe dope too. The orfice is really the only thing needed to change although it is calibrated so it will be fairly easy to change around
