Here is the answer to your MFC code 46
Machine Error 46 - Purged Ink Box Full MFC620CN/420CN/410CN/210C and FAX2440C
The
machine counts all purge (cleaning) operations in order to prevent the
internal ink absorber box from overflowing with purged ink. An "initial
purge", for example, advances the purge counter by 187 + 420 = 607.
When the purge counter approaches 6400, an internal "Machine Error 46"
is generated. Further purge operations are prohibited, and therefore
the printer becomes unuseable.
When an internal Machine Error 46
is generated, the user will see an "Unable to Clean" external message
and will be unable to use the printer. The "Unable to Clean" external
message can relate to many different internal error codes however.
The
user can establish the internal Machine Error Code as follows: pull the
mains cable out of the machine (power off), hold down the Menu/Set key,
re-insert the mains cable into the machine (power on). The internal
Machine Error Code will be displayed.
If there is a Machine
Error 46, it is necessary to dismantle the printer, replace the ink
absorber box (or possibly break the ink absorber box open and clean its
absorbent sponges under a tap), re-assemble the printer and reset the
purge counter to zero.
Resetting purge counter MFC620CN/420CN/410CN/210C and FAX2440C
1)
Enter machine maintenance mode (on MFC210C all four photo/copy/fax/scan
lights flash in maintenance mode). Care is needed in maintenance mode,
otherwise critical settings may be inadvertently corrupted.
FAX
models with numerical keypads: Press the Menu/Set, *, 2, 8, 6 and 4
keys within two seconds. (if you fail to complete the correct key
sequence within two seconds, press the Stop key to try again).
Other
(non-FAX) models: Press the Menu/Set and Black Start keys. Next press
the "up arrow" key four times to enter the maintenance mode).
2)
Press the 8 then 0 keys in the initial stage of the maintenance mode to
call up the machine's log information list (function code 80).
3)
Press the Black Start key several times to scroll through the log
information list to reach the purge counter. The purge counter is the
25th item in the list.
4) Press the 2, 7, 8, and 3 keys in this order to reset the purge count to zero.
5) Press the Stop/Exit key to return to the initial stage of the maintenance mode.
6) Press the 9 key twice to return to the standby state.
Clear browser cache and history, get malwarebytes free version and run it.;
