Echo Gas Blower 135 MPH390 CFM Blower PB250 Logo
Posted on Nov 23, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The motor bouges when u pull the triger - Echo Gas Blower 135 MPH390 CFM Blower PB250
Wade Mobley
Level 3:
  • Master 513 Answers
  • Posted on Dec 03, 2010
Wade Mobley
Master
Level 3:
Answers
513
Questions
0
Helped
279826
Points
1079
Check the carb needles ajustments may be off usually the high side is turn all the way in and turn out 1 whole turn and low side should be 3/4 turn out
Hard to start keeps cranking then fires over and engine flutters but still doesnt start till 2 more times then when you take off you give it gas and it bougs down and no power pops then after it warms up...
check for codes, if none then check fuel pressure and volume with a gage. pressure should be in the area of 35lbs unless this is throttle body which is about 15/18lbs pressure, if this is a vortec motor the pressure is 55lbs. the volume should be about 1 liter in 15 seconds. the vortec injection systems have a problem with the spider fuel lines that go to each injector cracking/breaking causing no fuel supply and leaking into the intake manifold and not going into the cylinders.
Hello got 2.5 l 4 cyl s 10 chevy and is runs very rough like its on 3 cylinders what may be the issue?
Start with plug and plug wires, This is the most common problem with a missfire. Can check by pulling plug wire off the plug with a pair of plyers and see if it is fireing, If it is fireing of it will cause the motor to boug down when you remove, then replace and will start back running the way it was , Do this on all 4 cly's and see witch one is your problem and replace. Good luck to ya.
How do i remove the bolt from the mossburg 308 win. and is there a product you offer to modify the triger
if i were you i would leave the bolt alown,,its a hell of a job getting them back in,,,as for the triger i know there a bit on the heavy side to pull at nearly 4 lbs but its a safe pull,you could drop the gun into a gum smith and get him to snip off a coil off the triger pull spring,,and stone the sear,, but be warned it will make the triger twitchy,,you realy dont wont to light a triger on a hunting rifle 4 - 6 lbs is normal
Nov 18, 2009 • Optics
Fuel filter & bouging down
U need a special tool to release then internal spring clip
1helpful
2answers
The tool attachment won't spray water-
you almost have to open up the unit and follow the hoses from the handle into the base.fill it with solution and turn on pull triger.hold the triger in and turn off the unit keeping the triger pulled.turn off and start it up and try again.if it don't spray you might have a bad pump.open up the unit and see if all the hoses are hooke up.there should be a plug on the handle .is it plugged in.please leave feedback.i hope i was some help to you...pet
2helpful
Welder feeding or arking
Release the wire feed rollers,turn the wire feed dial up to maximum ensure you are well away from the earth clamp, pull the triger, you should hear the relay click in, if it dosn't check the 5 mil anti serge fuse positioned on either the front of the set or on the control panel near the wire feed rollers inside the cabinet. usualy covered by a plastic screwed knob, make sure the unit is unpluged before any testing.
2answers
My modeal 580.752000 pressurewasher runs great but as soon as there is a load on motor [pull triger on spray head] motor stalls
Dear tenpointx2,
ngfam at you service!
This sounds like it will only fixed by service
Yes sounds like you need service!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
Neil
PS.Before you sign off!
PLEASE GIVE ME A GOOD RATING HERE ON FIXYA.COM
Top Echo Garden Experts
john h
vince
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you an Echo Garden Expert? Answer questions, earn points and help others
