SOURCE: Eureka Central Vac-Sweeper -Model B1501
Its not easy to get into the sweeper head. I would push a air hose in there and blow the head clean. You will need to find a compressor or your friendly local workshop manager could help you.
SOURCE: no suction with Eureka Boss Pro Lightweight Bagless Upright, 411A
I checked the vacuum hose to see if there was a clog. 1st, disconnect the hose from the unit so you have access to both ends. Now, place a marble or other ball in one of the hose and see if it will make it all the way through. I found a major "hairball" about 8-10 in down from the vacuum end. I took a metal cloths hanger and bent it in half and did a "roto-rooter operation. It took about 30 minutes, but now it runs like new. I hope this works for you.
SOURCE: Eureka central vac 's power stopped won't start again.
I took to dealer I bought from . He examined it. The motor is gone needs new one. Thanks, Ann
SOURCE: no suction on my eureka boss smart vac. The belt
Yes, try this:
Remove the beater bar again, and check the suction cavity behind it. This is where they usually plug up.
Best regards, --W/D--
SOURCE: bag model for Eureka Mega Boss 4460 type E
The model 4460 is for a Victory model which uses Eureka Type AA bags
They can be found at http://www.totalvac.com/eureka_aa_bags.html
